- Thread starter
- #31
I got to thinking that the backing plate is bolted with the nuts being on the inner side. I came across the following pic from when I removed my original brakes & wheel cylinder that has the bolts showing. Wouldn't I just need to remove the four nuts that holds it? Thanks again.... Ray
If it bent that easy,I would just bend it back. You have the axle flange to work off of. A straight edge across the flange and a ruler and you should have no problem.:Shrug:
Bendix type brakes always gouge the backing plates more it seems
Backing plates are stamped steel and pretty thin, go easy sanding the high spots
The plates still look bent at the top
Have the brakes always pulled and locked even before the overhaul?
Make sure the wheel cylinder isn't seized. Fords are famous for it.
The 4 nuts viewed thru the holes on the flange of the axle, remove them, you may need to put the drum on backwards with 2 nuts and use like a slide hammer to pop the axles out
I may be able to borrow one from an auto parts store if needed. I would hate to have to buy one.
No need to worry about gears falling out with this type of rear end ( only with C clip type rear ends) you need to use caution
That's great news!
Now with axles out look in the axle tube at the grease seal, if it is overly wet and grease build up outside the seal replace seal, be sure to lube the lip of the seal
Your axles should come out this way, tho the bearing seal may be different , there may be a seal in the rear end tube
That would be more than awesome.... If that's the case there wouldn't be a need to crack open the pumpkin, correct? Thanks Jack, appreciate ya! Ray ThumbUp
Correct
Thank You for all the great information.... appreciate it.
Whay are you wanting new backing plates?
Because all the high contact points for the shoes are gouged as shown in the second picture of post #36. I would rather have new plates than having them repaired and ground down. I don't have a problem having them repaired but, I would have to hire that out. Also, if they are bent, I'm not so sure I could get them straight. They look and feel wider at the top but as I stated earlier on, I never had a problem removing the right side drum. In other words, I never had to forcefully remove the right side.
That video is about the 9" Ford axle.
I was just referencing that video wanting to know if axle removal for my Lehman was the same as shown at the beginning. I'm not a mechanic therefore, I'm asking those of you that know one way or the other.
I looked at your pictures, you have an earl 6.75" integral type carrier Ford axle. Used in some Pintos, Mustang IIs, even some early Bronco IIs, Fairmonts, etc.
You're correct, they're are many Fords that used thes axles back in the 70's and 80's.
Lehman either shortened the axles or had new axles produced to fit the shortened housings.
The following link is probably the best info. you'll find anywhere in regards to Lehman rear ends. Especially, (RIP) Jim Murphys answer in post #2
https://www.triketalk.com/forum/threads/56158-Question-for-Lee-Mann-drive-axle-replacement-parts
Your axles will slip right out once you remove the 4 nuts that secure the backing plates and axle bearing retainers. The Mustang II Organization has a page on this rear axle, with exploded diagram. There actually is a lot of info out there once you search for Ford 6.75 rear axle. Here is a video goes back to 1960-61 Falcon, but those had a different lug pattern. You do not have C-clips holding the axles in.
I will definitely check it all out. appreciate the help.
Ok, I see they got bent a little. I'd bend them back, use a 2x4 about 24" long and a C-c;lamp to leverage them back to a proper fit with the drum, then build back your brake shoes / springs / hold downs / etc.
Thanks again Jack... This may be a stupid question......LOL. Should I drain the differential fluid before I pull the axle. I do have the rear end up on jacks slightly higher than my ramps. I just changed it prior to the brake shoe install but, of course I will drain it if needed. Thanks again. Clueless Ray (Headbang)![]()
Very little grease would run out if any
Thanks Jack... I'll be pulling the axles either today or tomorrow. Once I get the backing plates off, I'm going to check around a couple welding shops near me to see if they'll repair those grooves on the nubs. I'll give them a shoe for double checking across them for contact. In addition, I'll definitely check for the trueness to see if they are bent or not the best I can. Thanks again, appreciate ya big time for seeing me through this! Ray ThumbUp
Just for grins, as you have the shoes off and will be pulling the plates, pop the wheel cylinders apart and look in the bores, check the pistons for scoring.
Keep in mind new parts can easily not be OK, I have seen this many times before
I once got a spark plug with no threads![]()
Took apart the wheel cylinders, all looks great.... Pulled both axles with the left one needing to use the reverse drum trick as a hammer a couple times. After removing the backing plate bolts I gave both axles an up/down and side to side test. No play at all, nice and solid. As for the seals, they also look good.
After cleaning up the axles, I placed them back with the exception of bolting them in just to keep them off the floor.
I have a question since I'm a little.... well probably more... oblivious.With the trike being in neutral, I noticed something odd but, there must be a reason. As I was spinning the axle, I noticed the other side spinning in the opposite direction. After you're done laughing.....LOL. Please fill me in. :Trike1: Thanks Jack. Ray
Ray, that is an open rear end, one of the most popular on the road
Each axle can turn independant of the other
