No display on speedo
Hello everyone. I decided to powder coat some parts on the 2019 fw and the tank bezel was one of them. Have it all back together and the neutral light stays on all the time and there's no display on the Speedo. All the wires are connected correctly. I did forget to pull the fuse when I started. Could it be a issue with that?
Welcome to Trike Talk and your first post
Recheck your work and see if you have a bent connector pin in the harness you took apart
Please stop by the New Members Forum and tell us about you and your trike
Here is your set up, can u tell what all got removed?
Medium
So I tried the on off and nothing. I took off the bezel and removed the Speedo and rest of parts on bezel. The are on back like the were. I changed the handle bars but all the buttons work as they should except the top button that scrolls the Speedo. Any more ideas
Hold down the trigger button, turn the ignition to on with the run switch in the on position
Does the speedo needle sweep with all the other lights in the speedo lighting up?
This is what we call a WOW test, it tests all of the onboard systems and is an access point for scanning for trouble codes
You say you changed the handle bars, the trigger button has not worked since?
This may indicate a either bad trigger switch ( not sold separately ) or a pinched wire
Bullet Proof
