M8 Trike Owners Check Plug Wire
Jack Klarich
Gold Member
Oct 11, 2016
18,131
15,217
Jacksonville, FL
Jack
Check to make sure your plug wires are attached to the part of the frame behind the rear cylinder, this is my second M8 I have owned where the wires were not attached properly from the factory, 1 wire shows signs of the outer jacket having a burn mark
Jack......I was going to ask you if you could post a picture of the spot where the attachment should be made.....But i'm a little enbarrassed because i can't no matter how many time's i tried to post a picture over the years and failed.....:xzqxz:...:(..
I am not very camera savvy, my wife is so I will try to get her to snap a picture
Here is a video showing how to change the wires, @ about 6:19 on the video you can clearly see where the wires attach to the backbone part of the frame
If you look at the area under the ( front) seat, from the left side of your bike you get a straight shot @ seeing the wires and how they clip to the frame
Now I’m confused as a goat on Astroturf…. Had the four grandkids over most of the day so I’m a little zonked out right now I feel like I went down the road with one wheel off and the axle dragging… I’ll try to look at the pictures later tonight , Maybe I can figure it out then..?
The top picture is the right side view, the bottom picture is the left side view
Ron A
