Shifting into reverse with a manual reverse.
Ray55
850+ Posts
Dec 6, 2012
930
719
Santee, CA
Ray
For all you people with a manual reverse gear, how do you get it to shift into reverse without grinding a pound of two and without it almost giving you whiplash? Installed a MotorTrike reverse last week and when finished and tried to shift into reverse, it sounded like I had shifted gears without using the clutch. I know that is not good on the small idler gear and bearings.
In ''Neutral'' .....''Engine Off''...Reach down put the lever into reverse ..Then with the clutch in.. Start the engine ease off the clutch....And feed gas ...Thats the way i did it with my 2011 Tri-Glide......ThumbUp..
Bob, are you saying you have to shut it down before using reverse each time?
Wouldn't a good clutch adjustment solve the problem provided it was not a hydraulic( non adjustable) clutch
Let me Splane ....I pull in a parking space that i will have to back out of after I park the Trike , And then when i come back before i start the engine i slip it into reverse start the trike and ease off the clutch and back out..I never had to use the reverse with all the 3 Trikes i had....Mechanical or Electric thats the only time i ever needed to use reverse
If I am pulling into a place where I will need reverse, I shift into reverse before toeing it out of first gear.
If stopped, I do as above and start it in reverse.
Glenn witt
