2011 tri glide cams
I bought a 2011 Triglide in June of 2019 from the original owner. It had 30K miles on it so I wanted to check out the cam tensioners and bearings. I found that it had the S&S 551G cams in it! With the stock 30t trans sprocket it had all kinds of get up and go which impressed me especially after riding my 150+hp Street Glide!!!
Of course I couldn't leave it alone so 3 months later I had the heads ported by Jim @ Mega Flo. Wes Brown at Cyclerama found a set of his CR575G that I set up at 10:1 compression with de-catted head pipe and it ran way better and made 98HP /110 TQ when dyno tuned
Fast forward to today Mega Flo installed an 4 3/8" S&S crank, machined the cases for S&S 4.125 cylinders and pistons, 58mm intake with 6.2 inj and the G575G cams set @ 10:2 and it run cool not high compression and runs awesome! It dyno tuned 116hp/127tq.
Good luck
Boatpaddle
