Weird noise in clutch
no mounting just yet.
unfortunately i ran into a problem. things don't get my full attention until i'm working on them or installing them. i would have normally caught this and had it fixed. the wire harnesses from the tail lights too the bike were at one time spliced, right next to the connectors at the light. the splice's have 2-3 wires left holding them together. one is a dead short. these must be fixed. sorry the electronics tech in me just cant back yard this. might need new harnesses they very old the wire is very old. at least this is an indoor job.
the damage is to great and the wires would end up short or to long and not fit. at $15 each new ones are on the way. waiting again.
i got one side of the door done, with what i have. nice double coat of light pink, no clear im out. this paint really does not need it, none of the plastic is cleared. the fenders needed the extra protection. i'm going to let the door dry before doing the other side. it has to be laid down so to not scare the paint i'm letting it dry over night. i'll do the other side in the morning.
more to come on the fenders later.
If you can post a picture of the pant can; Ie The Brand...The rattle cans that i use never come out that smood and finished looking...ThumbUp....
.View attachment 91453
Good on you for getting new wiring:clapping: It never pays to cut corners with wiring IMO;)
I have seen electrical fires on bikes, it aint pretty
I had a bad fire coming home from Sturgis one year on a friends bike, Scared the Hell out of me
a quick update
THE WIRES ARE HERE 3 days late but finally here. the bad news is im sick, no its not covid in fact my test from thurs last week in negative. they tested me for the antibody today. i have a bad case of sinusitis from all the smoke in the air, my sinuses can only take so much.
4fenders are on
the fenders are on, the brackets are on the holes are drilled the fenders line up centered the side covers line up and the seat fits. bolts fit in the holes and everything still lines up. i knew i was going to need longer bolts i got those but ran out of steam before getting the final bolts in. also still need to install the door and the exhaust. then wheels. the first pic is of the wires install and tucked up. yes everything works.
murphy is in charge now
murphy is in charge now, and kicking my butt with little shit. first i had mounting bolt issues and went to home depot twice. i thought the old bolts i had would fit, no i did not check( damn brain injuries). so i got those done and the fenders mounted.:clapping: i went to mount the exhaust, i had bought short 3/8 bolts like all the rest for the exhaust. no i did not check them. when i went to install the 3/8 were too big so was a metric i tried. so i pulled the bolt holding the bracket and as soon as the 1/2 inch wrench fit i knew i was going back to home depot for 5/16 bolts. i got that done and the exhaust is bolted up now.:clapping: the door is on. the fenders and exhaust are finished.:clapping:
so now im mounting the seat i set it on and the rear bolt holes just dont quite line up, they dont go down far enough. so i need to cut 2 more notches in the fender so the seat will fit. this is probably what broke the seat there from the other fenders, did not cut notch in old fenders. :gah: no real big deal ill have it done by end of day and get the wheels on.
update; i cut the notches then pushed the seat all the way in. its not the notches the fenders are to high in the front. still an easy fix just cant use the nice rubber mounts. will have to thin it down and just use washers. also need 2 people cant reach the inside bolt and underside bolt with one person. so brakes on. :gah::gah:
ive been thinking, if i lower the front and raise the rear it will bring the front curve down and back. am i correct. it also just happens i have room in the back to go up and the front is a little tight and could come down. in my head it works i think?:confused:
update Thursday; well at least im not working today because i'm not able not because i'm waiting for parts or have no help. i got up this morning and could not move my body just had enough. i had help today but took a day off. so close and yet so far. i still wonder if i'm even going to be able to ride her i just dont think i'm strong enough anymore.
guess what i did?????
a friend came by around 11, i was in no condition to work. but he is my most knowledgeable helper. so i went out side. we pulled the front mounts, we then put the seat on, then we respaced the front mounts with flat washers. we then tried to bolt them up, the bolts were very crooked. so i had to redrill the holes. so to recap the fenders and seat are on, now we put on the wheels, and took her off the jacks.
YUP JOY IS ON HER WHEELS. i rode her and discovered the rear brakes need to be bled once more for air. the good news is they pump up this time so no leaks just trapped air.
View attachment 91929View attachment 91930
:clapping:.....ThumbUp....:clapping:...................................
my freind that did the painting help me bleed the front calipers rear lines. these lines are fed by the long lines and are the high spot on the frame. i got better peddle but it seems we need to do the rear. this is now covered by the trunk. the only way to get to the bleeder now is to jack it back up pull the right rear tire and then i'll have limited cramped access. i still have too tie things up on the upper frame around the steering. need to remove the dash and the inserts. she runs and rides smooth. the front brakes still work great.
thank you all i see the 24,000 + views wow thats a lot of support. it has helped me keep going, knowing there are people watching and cheering me on. lets go for an even 25,000 i still got a little work to do. she has not been on the road yet.
oh test riding her went well, i find out how much this is going to hurt my first road trip to the store. which will include taking my walker and walking at the store. i hope i make it home.
sort of, the rear brakes are still connected to the front. but the front brake only operates the front brakes. most of the factory lines are still there up too the connectors behind the radiators everything else is gone and been replumed. while i have no issues with the front brakes on the left in pic rightside on the bike they are isolated now no long lines to hold bubbles. the rear brake connection other side to the front is a different story. eurowing builders remove the proportioning valves out and direct connect everything. i still have the valves and the long lines on both sides. big issues with bubbles now that i fixed the leaks. if i had the money i would pull the rest of the factory lives and valves. direct connect the rear brakes and have just one line to the front. i believe its having the 2 lines going to the same place and using both valves is confusing the system. this is the way i was told to install it and the only way the lines fit.
added; on the rightside is the front brakes, you can see the caliper line the bent one on the bottom. the 2 lines coming out the top go to the calipers. on the otherside at the top are the 2 feed lines from the rear, they only fit here try it every way possible. the 2 on the bottom go to the calipers. its the top rear lines were im sure the bubbles are collecting. im sure having these 2 lines connected is messing with the proportioning vales which would cause pedel issues. except for the fact i have had a hard pedel, so i know im not done yet. i ran out of fluid, my air bleeder will change all the fluid in a minute. just pulls it through, have to push the peddle though weird.
The only reason I was asking if the front only operates the front,but the rears operate the rear and maybe possibly one side of the front. that could be where the issue lies.
joy is safe to drive
as i said the other day the guy that helped me paint the fenders came by and we got rear brakes working. i have pedal but they need more bleeding to harden it up. but they do work.
today i went out to fix the hose blocking the steering, i did not have full steering either way. on the left the throttle cables needed tucking in just a little. the hose on the right side turned out to be the small hose that connects the radiators it also needed tucking in. i cable tied everything up and put the dash back on. i now have full steering again.
new information; shes not legal to drive. when we were testing the brakes my freind noticed the left headlight was out. i just pulled it and yup its burned out. as i said murphy is in control now. still cant ride her on the street. i did however renew my registration.
$32
i got used to not driving, but i gotta go to the pharmacy.
JOY is fixed and legal. :clapping:
still need to bleed but that will get done, i changed the bulb she is legally drivable now.
:clapping::clapping::clapping:
off i go hope i dont die this is the same road i got hurt on. it a good thing i know how to ride huh. was making them dance before these punks were born, we were the first the ones who started freestyle. thats why i'm alive today.
:GL1800:
YEEE HHAAAAA
:wave4::wave4::wave4:ThumbUp:pepper::pepper:
oh yeah i forgot why her name is JOY, OMG i forgot that throttle and sliding sideways around turns. oh the way she hooks up while sliding. OMG and the way that front car tire just like glue on the road. i also found out which muscles been cramping lately. yup the ones i aint used in 18 months. she runs straight and true, needs some air, and i think i heard a squeak up front. but all good. i'm no longer stranded.
:GL1800::encore::encore::encore:
I can feel your smile here. You did a GREAT job, something to be VERY proud of:clapping:
my tires were low i thought she was slow and spongy, my air nozzle is broken. I got the air i needed. OMG she turns now and rides like she should. watch out for the steering it works real good. barley gotta touch it and you in the curb. that car tire is like power steering on steroids with a side of steroids. the suspension stiffened right up. yeah the way i like it moves so fast they back right off. she got her speed back. the clutch is fixed no more gear banging. she stops very normal, as fast as she goes anyway. shes like riding on rails that move.
:GL1800::yahoo::yahoo::yahoo:
