Rear Tire pressure- Brand Specific??
tourman
250+ Posts
Jan 20, 2012
314
98
St Paul, MN
Mr Sister
Does the brand of trike have anything to do with what your rear tire pressure should be? Or are they the same across the board? I read a lot of different opinions on what pressure one should run..
I have a RoadSmith HTS 1800 and am trying to figure out what pressure to go with.
Also what settings should the rear shocks be at if riding single- 200 lb rider?
tire pressure is different even for different owners of the same make/model. Over all weight is one of the big factors.
Mostly 22-23 PSI will do in tires. 25 was about the max I used two up & loaded. Shocks or air bag pressure varies depending on what you have.
wzejda
