My 08 CSC front tire was leaking air, almost flat in 5 days. I had a new tire installed, and overnight, it dropped about a pound of air. Is that normal? It went from 40 psi to 39.
Gerald
Gerald
Gerald
Gerald
Gerald
When temperatures drop over night you could see a pressure drop. Keep and eye on it. If it comes back up after riding on it, then it's temperature related.
Other things would be did they replace the valve stem? Maybe check the valve is snug in the stem? It's kind of rare, but, aluminum wheels can get pinholes or porosity depending on their environment.
It sure sounds like the valve stem to me unless you have corrosion around the wheel bead.
Some soapy water on and around the stem and bead will help to identify a leak, take the valve cap off the stem and soak the core you may find some bubbles, I like to push on the valve stem ( side to side ) when checking for leaks also
I would replace the Rubber Valve Stem. See attached photo.
I only use the ones with the nut on the top of the rim as in the above photo.
