- Thread starter
- #301
I installed a Custom Dynamics luggage rack LED light bar. Should have been a simple install but after installing (followed directions to the letter) and plugging the connectors together the light didn't work. I noticed that the wiring pigtail that plugs into the rear lights harness on the Freewheeler had a red / black / blue wire going into the connector and the wire pigtail from the light had a red / black /yellow wire. The wires from the light bar are loose and not snapped into the JAE half connector so you can feed the wires through the luggage rack rail and into the trunk. So, after running the wires into the trunk and through the plastic plug in the trunk and into the space under the seat I snapped the wires into the connector plug half, connected it to the wiring harness connector half and turned on the ignition....no light, running or braking. Called tech support and they said "you must have the wires hooked up wrong". I asked, why is there a red / black / blue on one side of the connector and red / black / yellow on the other side when the instructions says to match up the wire colors? I don't know he said. I will pull one from stock and check and call you back. While waiting I check wire to wire hook-up with my test light and then hooked wires direct to battery....everything worked correctly. Tech support called back and said their wire colors were the same as what I had and that I had connected them up correctly. I messed with the connector, unplugged the individual wires several times and re-seated them but could not get the light to work with the supplied JAE connectors. Cut the JAE connectors off and used individual wire to wire connectors...light works perfectly.
Sorry for the long post but pretty aggravating. Should have been a 30 - 45 minute project instead of 2 hours. Never had this problem before with Custom Dynamics products but in the end it worked out.
Sunman
I was looking at the instructions for that last night & the instructions under the Freewheeler looked like they were for a TriGlide. I was then looking at getting their night rider light and making my own bracket & mounting it under the luggage rack.
