Master cylinder for rear brake
May 15, 2012
5
Lowcountry, USA
Almost done with a 2003 Ultra Classic conversion. I used a DNA rear which has their 4 piston calipers. I can't get a good pedal. I have bled and bled, no air in system. I don't think the stock master cylinder has enough volume. Has anyone run into this problem? Any suggestions on a replacement master cylinder?
the Performance Machine replacement master cylinder for trikes is 3/4 it works.
Cscsonny, yes I have bled master and caliper quite a few times.
Rsw, it's stock Harley master. Don't know the bore size, have heard they are 11/16.
The problem is, the first time you push pedal, it goes all way to bottom and then second push, you have a fair pedal (not great) about half.
Thanks Gorrilla
brake lines
hope you got the master figured out I just purchased a kit still in route The kit doesnot come with rear brake lines .What did you use thanks
