Manual gives sequence to follow and amount to draw out, I'll do the vacuum way. I'm under warranty for three more years and though 'll get hit labor I'll let dealership do clutch at inspection (yearly in Pa). Manual wants clutch push rod movement measured etc. Brakes I've done lots of, hydraulic clutch s nadda. Man I miss cables
You're doing a vacuum? I was looking at videos on pushing fluid "backwards to the master cylinder" Supposed to alleviate air bubbles .
JK - that's what I thought, when I replaced calipers (cheaper than rebuild) just for something to do i d take old ones apart, lots of gunk on 60,000 mile plus units.
JK - MDO - did you flush clutch on pre 17's
I was comfortable with "old" stuff, everything up to the advent of internal oiling, ecm's, fuel injection. Now hydraulics. Is there and precautions to vacuum bleeding clutch.
Zerk fittings?
Are all three covers the same size
Old Road Dog said he modified the mc covers. I was wondering if he drilled/taped zerks into them. I have in my collection several type brake bleeders, (hand pump vacuum, pneumatic vacuum, homemade gravity, etc).
Apparently i opened a pandora's box when i asked if anyone has "tried" reverse bleeding. Although I've gotten interesting responses. Almost like asking what's the best motor oil to use.
