Jack Klarich
Gold Member
Here is a look inside the AIM slave cylinder
I see multiple seals on the piston I like this
What was the story that went along with this picture? I see a chip on the parting surface.
I was curious what gave the AIM actuator 40% reduced pull, i.e. different springrate
& or a bigger piston (more surface area). There is a big difference in price with the HD part at $60 & the AIM at $280:xzqxz:
I'm gonna have to swim against the tide on this one as I prefer the HD slave. The AIM claimed 40% reduction in lever pressure is probly due, at least in part, to the reduced surface drag of the o-rings as opposed to a square cut seal and maybe a lighter spring. Maybe me being 'old school' but I like the tried 'n true design much better and just don't trust round cut o-rings in this application.
Interesting point. From an engineering standpoint, the elastomer square cut seals are generally used more in static sealing applications than dynamic ones. If the materials, compression and gland fill on the o-ring is right, it can provide the needed seal reliability. Quad rings would be an interesting test (assuming there is an opportunity to improve on the improvement :laugh![]()
I got the call this morning and went to the Harley dealer, took 1 1/2 hour and out the door.
Just a quick update after the cluth recall was completed.
I got a 75 mile ride in today & could actually feel my fingers ( 60 & sunny).
The cluth operation is definately improved & if I had to put a number on it, I would say the pull is reduced 10-15%.
Also, easier to hold in at an extended stop. I'm happy.![]()
Just got my trike back today from having the clutch recall done. Can't say I really noticed any difference. I didn't have any problems with the clutch before I brought it in. At least it's done.
If it was not for the recall I would not take mine in
I have bleed mine 2 times and am having no problems
Recall done in an hour + a good wash job![]()
Well, what do you think? Did you get enough of a ride in to form an opinion ?
The pull seems lighter, other than that no big change cept my trike is clean
My dealer always washes bikes in for service
When I got there there was 2 other trikes waiting for the same service
All 3 trikes went in @ the same time, All 3 came out @ the same time
Pretty good service IMO
