**psi in rear tires...who is right? You guys or the trike mfg tech??**
We do not all ride solid axles, a majority rides IRS. The opinions here have been formed over the years from thousands of trike owners, riding many thousands of miles on every make, model and brand of trike and sharing that information. The best ride is going to be in the low to mid 20s of rear tire pressure. This pressure is perfectly safe and better suited in every way. Read this article from Lehman, it backs this up:
http://www.lehmantrikes.com/assets/docs/uploads/Manuals/techbook-master.pdf
This is an old comment, but seems I just discovered it, good info Zook, thanks for sharing. I need to re-evalute the psi in my rear tires. Lots of opinions, some post their ride, some don't, I like to see what others are riding.
I’ve intentionally stayed swayed from this one as I’m probably going to ruffle some feathers. I’ve drink a double helping of the old factory Kool-Aid. I run the recommended psi in both from & rear with the front tire on the front and the rear tire(s) behind me and the arrow (direction of rotation) pointing in the correct direction.
....... just something I’ve always done, and served me well.
OK, I'm hearing two different ideas here...
I have a GL1500 with a DFT Kit, everyone here says run 25 PSI in the rear.
The DFT Tech/Builder says you guys run 25 PSI because all of you have SOLID AXLES
The DFT Kit has IRS (Independent Rear Suspension) and that I should run 30-32
I pumped mine up to 30 but actually FELT better at 25...
Who if anyone is right and why? Your thoughts?? Thanks!
If you rear tires are car tires like mine. You do not need to run full weight in the tires. If they are on a car yes. Since you trike does not weigh near as much as a car, you need less air. I run 26 lbs in my rear tires and they wear perfectly. I am only on my second set after 66K miles and they are no where near worn.
Some automotive manufacturers recommend tire pressures as low as 26-28 for better ride. Early Honda CRV, and Ford Explorer just to name a few. A trike doesn’t weigh nearly what a small SUV does.
Yep.....And that recommendation, Put Firestone and the Explorer almost out of business!
And thats why tire pressure monitoring system's [TPMS] are required on new cars...
Exactly, Ford’s tire pressure was so low, and of course not many people actually check their pressure. It wasn’t long before tires were below 20 in a 4000lb vehicle
The only way Ford could get the soft ride they wanted was to lower the PSI spec
Firestone knew this and played ball until lawsuits piled up
It was too late then, Firestone rolled over but not before their own reputation was damaged
I never bought into that crazy low PSI for such a heavy SUV and I did warn customers of my opinion, it mostly fell on deaf ears at that time
Come On Jack with the title of this Threads subject line being https://www.triketalk.com/forum/thr...ho-is-right-You-guys-or-the-trike-mfg-tech-**
its pretty obvious we’re talking about trikes and not automobiles. My whole point in my post was that I follow the manufactures recommendations.
So, does the question becomes, since they are 'car tires' with manufacturer's recommendation based a 3K vehicle with four wheels with maybe three or four people and cargo of weight, become a bit skewed for trikes? Think I prefer the trike builder's recommendation.
Is this a legal or common sense thread ?
Devil's Advocate:
I would guess that the rear tires we run on our trikes were not designed to be run on the back of a motorcycle. They were designed specifically for automotive use.
Hypothetical Question:
If you were to run your front motorcycle tire on your car, would you run factory recommended air pressures ?? And if you wouldn't, WHY NOT ???
Hypothetical Answer:
Motorcycle Tires are not designed for an automobile, and visa-versa !!!!
Therefor, this an apples vs oranges thread and looking for a non-litigious answer defies logic.
Lee, I don't think this thread is about suing or getting sued, just how much air goes into the trike tire. Surely there are happy numbers out there, so opinions abound, does this become a 'flip a coin thing'?
I have been riding a trike for a while, this is one of the best reads on trike I have seen
I was told to go with 26 lbs. Huge car tires and not allot of weight with a trike like a car. The dealership tech told me 26 lbs and that is what I have been using to 72K Miles and 4 years. Just on my second set and still have plenty of life. I have IRS and air ride suspension.
I design and build custom trikes and the amount of air pressure is only relative to the weight placed on each tire. On all my builds the front tires are set to 17psi and rear to 24 (reverse trikes) On a conventional trike the pressure setting should be about the same ie 32 front and 17-19 rear. The ride will be better, tire life should exceed 40k and handling will also improve as you will get less rebound or bounce. 30 psi would be a disaster as this the the pressure used for weight of approx 900+ lbs per tire but the trike tires have only 250-270 lbs on each which requires a lighter pressure setting.
I actually void the warranty if the pressure is set over 20psi front for these reasons.
