'96 GL1500a brake/clutch fluid
Ol' Man Jeb
1750+ Posts
Sep 8, 2013
1,919
896
Newton, KS
Jeb
Trying to get my 96 Gl1500A MotorTrike road worthy and discovered my clutch/brake fluid is milky colored. I would like to bleed and replace fluid. Someone mentioned speed bleeders. How many would I need?
Jeb, I don't use them myself but if you are looking at bleeding the brakes and clutch yourself, you need one for each rear wheel, and if you still have a link running to the front wheel, you need one for the left front caliper.
The location of the clutch slave bleeder is within reach while operating the clutch lever, so you might not need a bleeder there.
clutch bleeder is notorious for clogging or stopping up though.
If you have a vacuum bleeder or turkey baster, drain the fluid from the reservoir and add new DOT3 or DOT4 so that you will see the clean fluid when the system is flushed.
Thank you for the come back, and here we go
Also, while you're bleeding do not let the master cylinder get so low that it sucks air into the system or you will be staring over from scratch.
I also believe there is a bleeder on the right front brake caliper that needs to be bled if the brakes are not linked. (There is on my 1800)
Almostagamer
