Oil leak at exhaust stud never saw it before...
Fearless
Gone But Not Forgotten
Dec 10, 2013
7,719
4,268
Clarion, PA
Fred Foster
I don't know what is going on but I'm sure it is not good does anyone have an Idea what is happening? Could it be a head gasket or cracked head I'm completely in the dark here. Help if at all possible. Fred
View attachment 56836View attachment 56837View attachment 56838
Looks like where my 11 Tri-Glide was was weeping oil, The cylinder head gaskets..
I never fixed it i just left it alone ,It started at around 25 thousand miles and i traded it in at 45 thousand miles, Outside of an occasional oil smell when the engine got hot it didn't cause any problems for me...But it will gunk up with road grime around the cylinder fins and make a mess...
how many miles on it? If it runs good I might just wait until it got worse. Or is it time to trade up?
I'm saying head gasket. Pretty easy to change but me, I'd be changing both front and rear if you going to take the time to pull the tank to change the one.
Just a note here: You could open a large can of worms here. Seeing it's an '09 I'm guessing the head/cylinder bolts have stretched. So me, I'd be changing them out....and while your at it change out the cylinder base gaskets. You could change out the bolts one at a time without pulling the cylinders but don't know you plans down the road. This whole project is based on "are you keeping the bike or getting a new one down the road"?? Pulling the cylinders means a whole lot i.e. rings and such. Or just ride it and enjoy the breeze. Maybe a slight hint of burnt oil every now and then.
Good luck,
8~\o
Thanks for all the input I have 25,150 miles on it I have owned it since 10/10/2013 start mileage for us was 7,872 miles. I am the third owner. All heat control done to the machine I have done, PV tuner, Tank lift and air deflectors thank Kevin DK Customs. Mighty Might Love Jug fans PaPa Zook. I went to visit a local independent wrench his theory is possibly valve seals are shot from heat and dried out sitting all winter I noticed a little stain at the end of last season of riding. The Indy also said it would be a good time to freshen the entire top end, most likely I will be going that way then I know what I'm dealing with. I plan on keeping it for as long I breathe, decisions... decisions... Thanks again for all comments and points to pondered... :good: ride safe Fred
Valve seals would not create an external oil leak,blue smoke at start up yes.As others have said would lean towards a head gasket.Just wondering,the rubber boot that covers the clutch cable looks as though it is resting against the cly is it possible that it has a hole in it and when you or your service guy lubes the cable oil is seeping out,I have seen stranger things happen.
I'm the service guy no It's not touching or leaking there thanks for the response Fred
Update dropped off Old Shiney the Harley Dealer service says they will take care of problem just as soon as possible hopefully this week barring rain for steam clean and test run to see exactly where it is coming from. Good dealer well recommended so I will keep updating as I get news and the verdict. :afraid:travel safe Fred
Thanks for all the input I have 25,150 miles on it I have owned it since 10/10/2013 start mileage for us was 7,872 miles. I am the third owner. All heat control done to the machine I have done, PV tuner, Tank lift and air deflectors thank Kevin DK Customs. Mini Might Love Jug fans PaPa Zook. I went to visit a local independent wrench his theory is possibly valve seals are shot from heat and dried out sitting all winter I noticed a little stain at the end of last season of riding. The Indy also said it would be a good time to freshen the entire top end, most likely I will be going that way then I know what I'm dealing with. I plan on keeping it for as long I breathe, decisions... decisions... Thanks again for all comments and points to pondered... :good: ride safe Fred
A refreshing at 25k ? Doesn’t make me warm n fuzzy. That’s why I got the extended warranty.
Update #1 Oil filter adapter screws into the oil cooler adapter then to the mount for everything I guess. Or so I was told and the service writer asked me if I change my own oil and I answered in the affirmative and asked if I ever checked torque on oil filter mount my answer no... possibly just possibly some of the oil making the lower part of motor oily is a loose connection, there. easy fix maybe.. No word on oil stain on lower exhaust stud. Learning experience to say the least I will not be getting a two wheel motorcycle this summer now for sure oh well I have waited 45 years now one more will not hurt me. :Shrug: DSC00763.JPG ride safe Fred
Update #2 The oil filter mount loose needs new gasket, rear rocker box also leaking small amount of oil, biggy is Stator seal seeping oil creating a real mess. Dealers tech streamed off head and cannot replicate oil stain on stud. while it is all in pieces I will be changing the front pulley to a thirty I purchased at a great discount from another member on the forum (thanks) bro. so I should be back on road by Friday. Amen!!! :D travel safe Fred
Sounds like relatively good news! I think you're going to like the new pulley! :D
Old Shiney was really weak pulling out almost to the point of slipping the clutch. It will be interesting to see if any other wear parts need replaced while they are in there ie compensator and or primary chain adj. possibly a new clutch the list goes on and on it is what it is at this point. Thanks for the encouragement. Fred
:mega-shock:
Update #3 Service manager says all goes well Saturday pickup let's all keep our fingers crossed going to be pricey though.. :Shrug: it is what it is. Fred
Update #4 New Castle Harley said it should be done on Saturday and they delivered! going to pick it up this morning. Pulley change and all will post complete repairs when I get back this afternoon.:yahoo: ride safe Fred
Just got back from picking up a very different Triglide we now actually have guts pulling out and there is a 6th. gear in the transmission New stator and voltage regulator the plugs were rotted off old regulator. and a whole bunch of new gaskets 10 year old Harley I am not complaining. The change to the 30 tooth pulley is great, now anyone in flat lands with a little more motor I would make a tremendous deal on a 32 tooth pulley. Until then it will be a door stop in Garage. New Castle Harley fixed us up in less than 10 day's this time of year good people great service at least in my world. We paid a good price for our service and I am very pleased Motor is all dried up no issues now at all. Travel safe Fred
ThumbUp-:clapping:-ThumbUp.......
Fearless, You seem to be pleased with the work that had to be done after about 10 years of Tri Glide ownership. Do you find that it increased the price per mile cost of operation significantly looking back over the past 10 years or are you thinking it was not that significant?
First repair I had to do since purchase in 2013. I have added things ie tuner raised fuel tank air deflectors changed windshields a half a dozen times and changed front tire twice. I have not one issue with the 09' I'm planning on keeping it until I die I can repair change what ever and not worry about Harley wanting to void a warranty. 44 months of ownership first repair comes out to less than $300 per year in repairs, I spend more than that on lottery tickets. These repairs were due to age not engineering. I even had the front Pulley swapped out from 32 tooth to 30 tooth while was apart time to get the same gearing newer models. Happy Harley Davidson owner. :bye:ride safe Fred
Great news Fearless, glad things went well, now you've got all the rest of the year to enjoy riding.
Repairs
That really sounds like GREAT news.........best of luck on your NEW RIDE!
Just a note to those of us with older trikes - both Wife//I have 2010 HD trikes
and I noticed that I had NO license plate illumination-checked hers and only one
was working (there are 2 incandescent in the trunk handle) - replaced all with LED’s,
easy job and VERY HAPPY WITH RESULT, rarely ride at night so who knows how long
they have been out!
:clapping:
I know this is not the correct place but..that portion is closed right now. I have the 32 tooth pulley with 25+ miles on it and I will never use it again. The only use I could possibly see is for someone in a very flat area that is running at high rpm all day long. I believe this pulley would work great for them, to lower the top end rpm in 6th gear. I would make a very attractive deal for someone interested. I got a great deal on my 30 tooth pulley and more than willing to pass the good will along. :Shrug: Ride safe Fred
Kickstand_Korner
