TG clutch cable-Now we know
Bikerbozo
Class Clown
Jun 9, 2010
4,580
903
Coram, NY
Andrew
For those who always wondered how long the clutch cable can last in a ‘10 TG....The answer is 130,000 miles....and change!
Mine broke on the Belt Pkwy in Brooklyn in rush hour. Rode it for 2 miles ‘till it was safe to get off at the Canarsie Pier. That’s 2 miles in traffic without a clutch. The TG is a lot harder than my old 2 wheelers to operate that way. Took 5 1/2 hours for Motow to get a flatbed not afraid to pick me up. 60 miles from home. And too late for any shops. Had flatbed back up to my trailer at home. Not that easy to transfer, but no way I could have pushed up ramp. Local shop has it now. Also noticing metal in tranny magnet plug. Might be getting time to rebuild that also.
Probably the radiation from where I was earlier in day ate through the cable.
Haa, The Belt Parkway......I know it well or used to it was one of the narrowest Parkways in the city.. I would drag race on the connecting highway , Before the Verrazano Bridge was built....Before 1964..
Is the Mill Basin draw bridge still there.. Cant tell you how many times i was stuck behind that when it was open...:gah:
They’ve been raising a lot of those draw bridges up and rebuilding going on on road right now. I can’t remember last time stuck at a draw bridge. Still heavy traffic. But smoother.
...And all that AGE you have accumulated, which you keep referring to... :p :xszpv:
If that’s the case , Indian Point is only 5 miles as the crow flies from me,
indian point is only 5 miles
indian Point is only 5 miles
indian Point is only5 Miles
But the word on the River is that the 3 eyed fish next to the outlet pipe taste better than shad...:Shrug:
That may be the best stash jewelry ever.....but I have to ask.....how the hell do you keep them from beating the hell out of you? I have trouble keeping my mustache hair from blowing up my nose!
jc
For those who always wondered how long the clutch cable can last in a ‘10 TG....The answer is 130,000 miles....and change! .......
I used to carry a spare routed next to and taped to the working cable to make a change easy. Of course I never had a cable break because I did that. Magic.
That was Standard Operating Procedure with the Victory iron frame bikes...Carrying a spare cluch cable....
Before adjusting a Harley clutch, I always lubed the cable and all hardware, let it soak in for a while
A properly adjusted and lubed cable can go a lot of miles as we see here
Keep in mind the cable will stretch some while in service, This is the time to adjust it;)
jc
Those are small colored rubber bands tying my mustache. Keeps it under control when riding, doesn’t hurt if it hits me....and....they hate it at work! Win, win aaand win.
The wife was using them to make bracelets with. I like the look better than black rubber bands I used a long time ago last time I wore it like this.
When I had a ‘77 FLH I used to carry a spare clutch cable. That one attached externally. The TG cable is internally connected. Not something you would want to try on the roadside.
Now on to other fun stuff. Tax refund check on the way? Check. Mortgage finally paid off this month also? Check.
At 130k service a couple weeks ago mechanic noted some metal particles on magnetic plug in tranny. When replacing clutch cable and replacing fluid just a couple hundred miles later. Fluid clear but still metal. Mechanics believe it is bearings in tranny getting ready to go. I will probably give it to them in next couple weeks to pull tranny and investigate. Probably new gears also (hey, 130k on HD tranny sounds pretty good). Not like that money was going to be doing much in bank anyways. Rebuilding tranny seems like a good investment to me.
Lol....I thought they were beads....the bands make much more sense. Too funny and thanks for the answer. I do like the Win - Win - Win!
Can't tell from that picture if it's a nuc plant or not. All that is the cooling tower or portable ocean.
Tranny rebuilt in a week or so. With no issues. Probably would have sat at HD for a month. A couple hundred miles on it now with no issues. Crisis averted for once. The bearings were all falling apart and they had a hell of a time getting them out. The gears had wear circles where bearings ran. Not horrible. Replaced them and main shafts for good measure. Clutch plates all good. At least I didn't blow it on road for once.:qpnmt:
Welp, hopefully things happening in threes has run its course for me. One of my front brake calipers seized up on Sunday. Had to bleed pressure out and not use front brakes to ride home. Seems to be near impossible to find replacements. Local dealer had one side but not other. Independent shop couldn't find any good aftermarket for me. Another HD said they never fail and they don't ever stock them. To lazy to check in his computer. Finally found a new set on Ebay in California. So won't get them until next week.:mad:
Ron A
