hogmemberisold
3250+ Posts
Had a tire shop bugger up one of my Pacer rims while putting new tires on. Rosy
That's one of the reasons I change my own tires!!!
Good luck on a resolution.
Had a tire shop bugger up one of my Pacer rims while putting new tires on. The 2002 Hannigan takes a 15x6.5 42-44mm off set rear mag wheels. Tire shop cant find any Pacer wheels to mTch what I had. They put a set of Americans on and the tire rubs, enough to wear the side wall. Two questions:
1. Has anyone replaced the rear mag wheels on a 2002 Hannigan, or early conversion?
2. Shop is going to machine the American wheels by 4mm to 6mm to get an off set to clear the fenders, will this hurt the wheel's strength?
Thanks for you info,
Rosy
I remember doing that to my cars and then getting use to the clutch all over again. "Feather" the clutch so you wouldn't stall the engine!
Yes, adjust and get ready to retrain your brain as to how much you can let it out, so it will engage!
But, You can train old dogs! Correct! Speed shift is in the past, now days, just shift so you don't jerk your passenger! LOL
Rosy
OK, need help, my headlight keeps going out. I just replaced it about 1000 miles ago, if that. Anybody have the same problem on their GL 1800?
Rosy
Alienwulf, let us know how that plastic dip works out.
I put on a new set of BF Goodrich 225/60R-18 rear tires to my Stallion. In addition, I added a Sirius-XM antenna to my Garmin 2820 gps. I hope that the Bluetooth LG headsets work as well with this arrangement as they do with other audio applications I have.
pmar6004 I
I washed it and finally rode it for the first time in a month. I got hit with Bell's Palsy four weeks ago, and couldn't blink my right eye until this week, so it would blurr out on me making seeing the road kind of difficult.
It was nice to finally get back out in the wind!
I finally installed my new handlebars and cobbled some pegs together from Kuryakyn to fit my 1 3/8 diameter down tubes. Have a look.
View attachment 44818View attachment 44819View attachment 44820
