Windshield vent in '02 Goldwing Trike
RUMRUNR
100+ Posts
Oct 25, 2016
130
72
Basehor, KS
Delbert
Hi folks, new to the forum, I have been reading post for a couple of months.
I have found my trike and should pick it up this weekend.
Here's the question: it is an '02, can I buy a windshield vent and cut it in myself.
Where can I purchase the vent?
Thanks,
Rumrunr
Thanks,
Rumrunr
Here's one of the best places to shop for your Wing. They have more then you could possible want I'm sure .... This vent is OEM fit and finish so I think with care you could make a pattern and cut it in. http://wingstuff.com/products/3916-...text=gold_wing_gl1800-windshields_accessories
Plenty of folks have cut the hole in the windshield and installed a vent. There are both OEM and a few different aftermarket ones out there. There is a difference between the 1500 and 1800 vents, and some of the aftermarket ones are slightly different, even though they are for the GL100. Some are best with OEM type windshields, and some are made for aftermarket screens. Not all are exactly alike. As to where to get a vent, places like Cyclemax, Wingstuff, Ebay, any OEM or aftermarket Goldwing shop should have or be able to order a vent. As I mentioned, make sure the vent you get will work with your windshild.
FYI - here are instructions for the Add On Accessories vent on a stock windshield. Other brands will be similar. https://addonaccessories.net/media/wysiwyg/45-1252N_inst.pdf
Great help, thanks
My skill-sets can cut a hole, however, cutting one on a curved surface, that is the correct size, and in the correct place, and finishing it with an even, smooth, rounded edge, is where my attempt would fail. If it's not even, smooth, and rounded, it can crack. If your skill-sets are similar to mine, I'd recommend a windscreen that already has the hole.
Someone who has a small router, a large work table, and the skills to make a "curved jig" to follow the arch of the windscreen should be able to cut the hole. Another curved jig will probably be needed for proper edging. A person with those tools and skills will likely succeed.
I've got all the tools to do the work and have worked with plastics before, so I'm going to give it a shot.
Thanks for the reply.
Yours should then turn out good. As a reference, if you want its position to be like OEM, with the vent door fully open, and the windscreen in the full down position, the vent door rides about 1/8" above the visor.
If you don't already know, a GW shield is hard coated polycarbonate. It is not likely to crack even if the hole you cut is not perfectly smooth. It is not acrylic and therefore is not brittle and subject to cracking easily!1.Place the shield in it's lowest position before checking for clearance!
2.Masking tape on windshield, position front side vent piece, as it would mount, on shield, trace around it.
3. Place inside vent piece on shield lining up w/traced line, flash light on tape will help you see the line through the tape. This step is to ensure the inner vent piece clears your dash top!
4. Cut hole.
If you use a jig saw, make sure the blade is for plastics. I used a sanding wheel on my small rotary drill to smooth the edges. I also coated the cut edge w/clear finger nail polish to prevent possible delamination of the hard coat!
4. Cut hole.
Thanks for the info, never thought about sealing the raw edge, good tip.
Bullet Proof
