2016 Tri glide handlebars
​ think im gonna give it a try i have to study and do my homework first and i'll let yall know when i do it , thanks this is a kool site
It's not rocket science
Take your time watch the video and take pictures if not sure. you will be very proud that you did it yourself and you can set the bars exactly where you need them ThumbUp wrench safely Fred
don't believe you will
I can't think you need to extend any wires possibly relocate some there is usually enough slack. I can't say for certainty mine is a 09 cable clutch. not anywhere new as yours. Fred
i wonder if i need to get any wire or connection that wont be long enough?????
hey Waldo I have been trying to reply but was having computer problems it would not let me type a reply. I have a 2014 and the dealer I bought it from quoted me about a grand to install the bars but he was replacing all cables and told me it could not be done with out them. so while I was down around Cantonment Fla. I stopped by the HD shop and he promised me with the reduced reach I would not need anything extra and he was correct swapped them out with no problems and there is a world of difference. Just be real careful with the throttle wire it is very thin. take pictures so you can refer back to how it came apart and you should not have a problem.
Thanks , after looking at the video im gonna do it , take pictures and label all parts, i saw i'll have to cut the TBW clip then re solider them to go through the bars, ok not last night i got on the bike and the reach is pretty good just to low i can afford to come back a couple inches but i do need to come up about 4 or 5 , i took a measurement of the stock bars and its 31 inches end to end .
Can you disconnect plug ?
Can't you disconnect the plug pull it through and reinstall it or is it to short exactly which set of handlebars did you plan on using? good luck take your time. Fred
Only cry once!!!
now that is what it is all about only cry once your are only getting started trust me. ThumbUp I did not change bushings on old Shiney to each their own. I believe you will love the grip angle on the wide sweepers to me they seem so much more natural to hold on to. :cool: wrench safely Fred
I ordered the 2+2 WIDE SWEEPERS , NEW BUSHINGS, new slip on's , hwy pegs, floor board extensions , gonna go all the way with her,
Oh yeah , i see where i can unplug it but the plug in side wont go through the handle bars with out removing it so its just 4 wires so ill cut and solider color to color cant go wrong at least i hope lol,
plug on end may have release
:Crap: A good number of those plugs have releases on the wires I don't know if the TBW has though would save splices if it did. fearless
You can un plug the wires from the plug, gota release the locking pins at each terminal. Take pix or mark as to ware they get plugged back to.
The Khrome Werks 2+2 narrow Sweepers are great, I'm 5'7" with 29" sleeve and they work great for me
Would that be part # 300519 ? Or 18 ?
300517A on the site but they told me that sites like JP cycles use different numbers and in fact that site said it would not fit my but the owner at Krome works said that the one for me it was the wide, and yes i did see where the pins come off and i will do it slow maybe this weekend if its raining here for sure i'll post picks and update again thanks to all who guided me
Take your time
Not hard just take your time you will love the changes and be able to say you did it yourself ThumbUp
Well i got the exhaust on last night wow now it sounds like a HARLEY should, will install the HWY pegs tonight with the floor board extenders , now for the bad I ordered the sweepers from J&P and the bushings ,well the bushings came in and no bars so this morning some lady tells me they processing and cant locate them in the warehouse, so i call again this time i got a new lady that knows whats going on so she said it will go out today hummmmm but the bad thing is when i ordered the exhaust i did over night and got them 2 days late so they gonna refund me but dangggg man , so thats where i strand
Stay with them
If you are clear about you expect about the shipping costs they will make it right I have had the same thing happen to me and they are a stand up company going through some pains themselves. keep us posted . fearless
Update , got the floor board extenders on last night and put the hwy pegs on but didnt set them yet until i get the handle bars on, got a shipping update they will be here monday so i have to wait on that but i'll take all the stuff off this weekend and post pics
J&P had some real problems with moving their warehouse this year. Hope they got everything straightened out. For a while they were running 90 days + behind.
I ordered mine from Krome Werks directly and it took 3 days.:Coffee:
You can use a needle to release the pin locking tabs from the connector. You then pull the wires through and re-insert the pins into the connector.
Bob :D
Well i got it took all apart all went well EXCEPT that little Trip Reset Button i broke it but all is good i'll get them to order one and swap it for me the reset still works i have to use my finger, the handle bars will be in today so i'll start tonight and it looks like the TBW wire will slip right through without taking them apart , i took them out the other bars with no problems at all here are the pics, oh i did swap the bushing also got ride of them flimsy rubber ones
HERE are more pics
Bars are a subjective preference... what feels good to one will be all wrong for another. Take a look around at other riders and see what they are using, and most would gladly (I think) let you check their setup out for feel. I am 5' 5" and went with the HD reduced reach bars on my '14 TG. Over 50K miles later I traded it in on the "17, and was happy enough with the bars that I had the dealer install them on the new one. By the way, they also come in black and with the wires run inside the bars, they look as sweet as they feel!
Again, just my opinion :Trike1:
Do you have the part # with the throttle installed ? Tks.
i installed the polyurethane bushings was easy, what part number ya looking far, the sweeper bars if so its the one that ends in 17A, i called them and he told me thats the one i needed
ok here ya go
Now i caint seem to find where that small plug goes with the black and white wires i dont remember unplugging it but i read that its for heated hand grips does anyone know ????? thanks looks like ill be done tonight , man what a difference just sitting on it :pepper:
on mine, the right heated grip gets plugged into the center of the DBW . Two wire plug. Then the rubber cap covers it. I think it's what you ask :Shrug:
KRC
