2016 Tri-Glide Ultra Fuse Box Location
I believe the big 40 or 50 amp fuse in that block takes care of the ecm and everything else. Its the main fuse.
#6 is the ECM fuse for a 2016 Touring Model
I was thinking the 40 amp fuse was the one as well. The diagram provided looks nothing like the fuse box I have am I missing something?
No you are not
The above diagram is a 2016 Touring HD
Your fuse block is under the l side cover?
The box cover should be labeled, the 40 amp fuse is the Main battery fuse, there should also be a 15 amp ECM fuse
Pulling the main fuse disrupts ALL power so if you are working on the system you will have no shorts to ground with that pulled
I hope this helps
Jack,
The fuse box I have on the left side looks nothing like the diagram plus I have less and lower amp fuses. I will take a photo of mine and upload it tomorrow and keep looking to see if there is another fuse box.
Jack,
That will help
HD down sized the fuse box, I dont remember what year
Do you have a 50 amp main fuse?
If you do you may not have an ECM fuse HD can bus systems use less fuses
2016 Tri Glide fuses.
My 2016 Tri Glide fuse box (under left side cover) has only 8 fuses and 2 relays. It has a 50 AMP main fuse. I do not know anything about another fuse location.
From left to right in the fuse block :
Top row #1 is Radio Power 20AMP #2 is System Power 7.5AMP #3 is Battery 5AMP
2nd Row #4 is P&A (parts and Accessories) 20AMP #5 is Cooling Twin Cooled 10AMP #6 is Spare 5AMP
3rd row #7 is P&A Relay #8 is cooling relay (twin cooled) #9 is Spare 7.5 AMP Right below 9 is #10 and it is Spare 20AMP.
The main fuse is 50 AMP.
RCK TMS trike
