Stage 1 on cheap
Jul 4, 2015
14
2
Hendersonville
I am thinking of upgrading the exhaust on my 2015 Freewheeler with some Vance & Hines Twin Slash from JP cycles, a DK Custom complete hi flow 606 air cleaner with stock cover and a FL- Vied 10 fuel enrichment. If I install them myself I will have about $675 into and I hope an inprovement in sound,temp and power. Would like some opinions.:pepper::mad:
2014 - I self de-catted my stock head pipes and added the FL-Vied-10s to my 2014. I kept the stock mufflers.
Sounds louder, way less right side heat, runs better ..... same gas mileage. :pepper:
www.wildpigpipes for de-catted stock head pipes is a great cheap option.
Bob :D
Thats all you need to do, unless your going to drag-race! 👍
Don't forget the tank lift ThumbUp got mine ordered, group here highly recommend for alleviation of engine heat on the Freewheeler!
Thanks Bob think I will keep the cats in place for now but if I don't get the results I am looking for I will look into the wildpigs to de cat
Jim
No drag raceing ,I like go and slow ride mostly mountain roads.
cooler motor
My old 09 sure liked the tank lift more air on motor less in face, you can tell by the number of bugs on tanks and their location on it. :D Ride safely fred
Tank lift is a good I seeing I will be ordering from D K Custom
I have a similar set-up. Same mufflers you are considering but I went with a K&N filter in the stock air cleaner that I opened up a little for more air and a V&H FP3 because of it's tune ability feature. This gave me lots more mid-range power and a great sound. Tip: if the Twin Slash rounds are too loud for you, remove the baffles and wrap them with fiberglass made for 4-stroke motorcycle mufflers. This will mellow out the sound and make it deeper. Forget the V&H "Quiet" inserts for these mufflers. They take away the rumble and leave a higher pitched sound. By the way, these mufflers look great on a trike and don't hit the ground like the stockers do. Good luck.
