RedOregon
300+ Posts
So I love my 2015, customized it a lot already, hearing a lot of great things about the new engine. Anyone know if they're compatible... could I plunk down a few bills and get one of those bad boys plunked into the '15?
Get the heads done with a piston swap to increase compression and a cam change and you will have more hp and torque than a M8 for a lot less money.
This is very true but it would still be way cheaper than an engine swap.And one could do the same for the M8 and ....
Sure it will fit if u have the bucks the frames are the same the drive train is ALL newAnd one could do the same for the M8 and ....
I think it will retro fit but It is on your dime JMOI looked at a new TRI "17" sitting next to a new TRI "16" today and it APPEARED (no one at the dealer could tell me for sure) but the trans looks slightly different between them and also the combination motor/trans sits slightly off set to the left in the 17. It looked like even though the frame maybe the same either the mounts are different or the mounting tabs might be different. So my UN-Official opinion is that they are not interchangeable except maybe with serious modification. Just what I observed.
