Post Your VW Trike Pics
Here's what I just got done with...
top of the frame is Honda GL1100 as well as the forks, front wheel and handlebar assembly. The rest is hand built. 1776 engine, side draft CV40 from a Harley (modified) under the seat. It runs great, is fun, is stable and reliable. The fan on the oil cooler is set to come on @ 180 degrees oil temp on the outlet back to the motor and rarely comes on. Some heat off the engine @ stop lights in hot weather but none going down the road.
Looking to build a leading link fork and figure to mount a car tire on the front once I get the trail right.DSCN5644.JPGDSCN5643.JPGDSCN5642.JPGDSCN5641.JPG
First, welcome to TrikeTalk Gleep!!!! Glad ya found us man.
That is a very sweet looking mid engine VW trike. Very clean and great lines.
Have you got any pictures of the side draft carb and how you set it up and what not? That would be great information for the VW trike forum.
Info for the Carb
Here's some pic's of what's under the seat and tank. The carb is a Keihin CV 40mm, polished bore, 48 pilot and 185 main jets. Needle is set (adjustable needle) with the clip 1 notch below center. The pressure spring on the top of the diaphragm has had 1 1/2 coils cut off to make the needle come up sooner. The vacuum hole in the slide has been over drilled to 1/8". The intake is 1 1/2" exhaust bends fitted together and TIG welded. There's a brace from the bottom carb bolt to a hole in the top of the transaxle case to stabilize the carb and manifold. Air cleaner is from a Harley Twin Cam, cover removed. Snug fit but it works.
That is an excellent looking setup Gleep! :clapping:
That 40 carb feeds the engine good being a 1776?
Reason I have asked these questions is that I am sooooooooooooo fed up with fooling around using the dual POS EMPI 40 HPMX's that I am looking for different options.
I have thought about grabbing one of the 2bbl progressive carbs but I have mixed feelings towards that route due to some fairly bad reviews.
The old time Weber's 2 bbl progressives were great but the new EMPI version has some fairly bad reviews.
Well stinger, gleep did a lot of research and question asking on his build.
One thing is the choice of cam to use with a single barrel.
CB 2208 cam. 8:1 CR. 53cc chamber "stock" heads from MOFOCO. The carb is gravity flow (eliminated the fuel pump) and it's never "starved". Power rolls on good from idle all the way up to highway speed, nice and smooth. In the county roads ans twisties along with hills, it'll roll on fro about 15 on up to 60 in 3rd- perfect cruising gear.
True- but a couple choices remain. I had an 1835 in a bus, big valve heads, 9-1 CR, forgot what cam but it came from Claudes as well as 1-1.25 rockers. I had the Weber progressive on it (single) and it ran like a stripped ass ape. The Weber progressive is fairly easy to set up to- there's lots of people running them and lots of infor and experience out there to get it real close bolting on first time. That really was my first choice but just didn't have enough room under the tank with the way it came together. Still have the carb sitting here.
On the other hand, the CV was a true "shot in the dark" with no one I could find ANYWHERE ever using it to power a VW engine. I DO know that it will power a 110" Harley (I do those too) so I figured "nothin ventured, nothin gained. :)
Right Gleep. The trouble is, it is pretty tough to actually get a true Weber 2 bbl progressive. Everyone is selling the dang EMPI crap and it is just that.........Crap.
I have a fella here in town that actually has an original Holley Bug Spray. Not sure how well that would work but I think I'm willing to give that a shot. Them were, however, basically a performance upgrade for a stock 1600 so not quite sure how well it will work on an 1835.
And, I know its long overdue, but here is a few pics of my VDub trike.............Finally. :laugh:
Nice!
I've found, with Webers, that if you get them good and clean on the inside, get 'em dialed in, keep your fuel filtered and the pressure @ no more than 3 pounds they work good. Have you thought to just run a single Weber in the middle?
Nice!
I have thought about running just a single in the middle. I may give that a shot. Of course these aren't actual Weber's. These are the EMPI knock offs.
Help with a conversion
I am a US Army Vet, I own a VW Trike, manual transmission. It has been sitting for over a year because I lost my left leg. Does any one know of a way to convert the foot brake into a hand brake OR convert the foot clutch into a hand clutch? Either way I need to free up the left leg side since I have no use of it and I truly would love to ride my trike once again.
Kep71
