independent suspension kits.
Jan 10, 2016
48
6
madera ca.
I was looking at some irs kits for my 2011 tri glide. there not cheap for sure. I was wondering, do those kits have a differential like a car so in turns, the rear wheels turn at different speeds or are the set up like a straight axle. has anybody converted a factory tri glide ultra to irs and how to you like it?
The DFT kit is not like the TRIGlide straight Axle . IRS versus straight axle
CAll them or see the video may help with your questions..ThumbUp
The Tri-Glide is what I consider a short wheel base/narrow stance trike.
While I have not actually tested a tri-glide converted to IRS, I have tested a HD Ultra that was converted to a after market IRS conversion that was also a short wheel base/narrow stance.
While there was a noticeable difference, the IRS gave a slight smoother ride, I would not spend the thousands it would cost to convert a tri-glide over to an IRS rear end.
Having said that, if I were considering converting a Harley 2 wheeler to a trike, hands down the best ride would be the Hannigan. With it's extended wheel base and wider stance along with it's almost maintenance free IRS, it's the winner IMHO.
BTW, could you post some links to the companies that will sell just the IRS rears that would fit the Tri-Glides. Thanks
All street legal Trike's have a differential [open axle] straight or IRS, Or they would flip like the ATC'c of yore...
And would be illegal for sale....
V8 Chopper trikes have a 9" Ford rear w/limited slip differential. If the clutches aren't set up correctly,it can cause the trike's front end to "push" in corners.
ATC's did not have a differential. They basically had a locked rear end which caused them to act the way they did.
I think all the conversions for the Goldwings have a differential from autos. I do know the Goldwing/Roadsmith conversion my Brother-in law had was a ford Diff.
The DFT conversion for the TriGlide to IRS is a belt drive also.
Yep i had 3 ATC's, My Sons and i ran them into the ground, Flipped them a few times, Part of the fun of riding them though the woods... But we were Men... Never once did we ever think of Suing Mother Honda!.. We didn't need the Government to tell us we could get hurt on them...
http://www.lat-enterprisesinc.com/power-arm-suspension.html
MRB
