Engine Upgrade
pddgm
90+ Posts
May 15, 2014
93
19
Sunrise Beach, MO
Smitty
Thinking about upgrading my 2008 96 to a 106 cu in using one of S&S kits. I know I will have to upgrade the cams and most likely add a tuner. Wondering if anyone else has done this and what were your results.
Joe
Joe
There is more to what you need beside adding a larger set of cylinder with pistons and cams. Honestly you need to speak with several shops after you decide what your goals are for power.
Some of the question that should be asked by a shop should be
1) What kind of power are you after? ( Hopefully you know its torque not horsepower )
2) Do you ride on interstates or back roads?
3) Do you ride solo or 2 up?
4) Do you tow a trailer
As far as costs, that will be based on your bank account and what you want for realistic power and performance
You should factor in
1) Flywheel work or replacement. New crank bearings both right and left side
2) Obviously the cylinders and pistons
3) Head work
4) Cams and cam bearings
5) Cam plate and oil pump
6) Piston oiler jets
7) ECM tuner ( TTS Mastertune, Power Vision, etc )
8) Dyno tune
9) Exhaust
10) Clutch pack and spring replacement
11) Final drive ratio change Front pulley/Rear pulley and belt upgrade 30/70 or 30/68 ( Since you have a 08 with a 32/66 ratio setup )
12) Labor costs for those things you choose not to do yourself
All the above is part of the cost and recipe to make reliable proven power for a trike. Like I said there is a lot to consider before jumping down the rabbit hole to add power to your trike
Thanks for the info and input. I am not going to go that extent to upgrade the motor. I have read a lot of the info on S&S's kits and the one I was looking at does not require any flywheel work or boring of cases. Since my 08 has the improved oil pump and plate, I was hoping not to have to replace it. I do ride all the roads you mentioned, two up some and pull a trailer some. The bike only has 26000 miles on it and runs good. Guess I will need to find me a good indy and see what they have to say about it. If I have to spend as much money as you are suggesting, maybe I should just buy a 120. Thanks for the info.
Joe
Something to think about. Harley has a bolt on 110 kit (cyl and pistons, part #92500039). Not a lot of feedback yet and some concern about the thin wall spigot area of the cylinder holding up. I'll be watching for more feedback as more of them hit the street.
Any shop worth their salt will advise you to have run out checked to start. Then go from there. Riding a trike with a passenger and pulling a trailer with more power could cause the flywheels to shift.*
I have a 08 myself. Hit 30k miles and had to rebuild the engine.*
As far as a 120 goes, I would suggest you look at the S&S 124LC complete engine if you go that route. A 1yr warranty and better engine as a drop in.
Joe
There have been reports by reputable builders that some of the 110 cylinders in this kit are out of round from the start. They have had to overbore them to true them up.
For what it's worth on the 110 bolt in kit from HD, it's looking like the luck of the draw with them. I have been told of out of round to start with and others come in OK. That said I have also been sent a few pictures of the spigot cracked as well already!
So for the time being I could not recommend them (HD 110 bolt on cylinders) in a Trike due to the heavy weight all the time and the additional heat generated by them.
Thanks Steve, was thinking about asking your opinion as I will probably be having a set of your cams installed this winter. Seems like they would go well with a 110.
They go very very nicely with a 110. I have over 12k miles on my TTS-100 in my Crate 110 motor.
