Handle Bars
Sep 14, 2015
23
3
McMinnville
Is their a way to adjust handle bars on a 2015 Triglide with out going to so much work. I mean is there a way to just loosen two of the handle bar bolts enough to move the handle bars a little?
handle bars
You can take two screws out of the ignition cover and tilt it down to access the the bolts, loosen the two you can see and the bars will move. Pretty easy:)
handle bar adjustment
Your right Leonard you can and I did. Thanks, that was easy. I used a real long 1/4 inch allen with a 6 point 1/4 inch bleeder wrench for good leverage. Got to road test it but it is raining here in Oregon.
Thanks...............Mick
Thanks for that bit of info. I've often thought about trying to change the angle on our handlebars but kinda thought it might be more work than that. I might give it a go,now.
2014 - From the factory they are pretty close to the fairing .... are they splined? .... and can they go any closer (more upright)?
Bob :Dorag:
Bob :Dorag:
They are knurled. Just loosen the two back bolts and push the bars forward til right before they touch the inner fairing. Remember, they are rubber mounted, so there is some play in them when pushing or pulling, make sure to account for that so that they don't rub/touch the inner fairing when pushing forward on them.
SOSMentor
