Upper back and neck pain, are the bars set right ?
Jun 26, 2015
127
22
Stafford, VA
Don
Hello group. I got a question. I'm not a big guy. 5'8" ( 5'9" on a good day). Recently have noticed some pain in my upper back lower nck region. I find when I sit back to use the backrest my arms get fully extendd.
Anyone expwrince this this and or did you change your bars. If so what did you have to pay to dealer? Can they adjust correctly?
You probly don't need to change the bars, You may just need setback risers. They raise the bar up and back so you can sit against the back rest. Can't help with the cost. Installed mine myself.
Thanks!
Will that hat work with the new triglides?
probably not..as the fairing area does not have much room to add the risers mentioned
It will help with the push pull when turning..That was another reason I traded in the TRI..The neck/back pain..
Good Luck on whatever you decide..I seen your posts...ThumbUp
I don't think the stock bars can be adjusted enough to fix the problem. You probably need to get new bars that are wider and taller. Depending on your build and arm length, you may need the bars to come back to you a little also.
My dad had the same problem, he ended up going to the pull back bars HD has. A riser change wouldn't work due to the fairing cap with the ignition and other switches. A bar change is pretty much the fix.
neck and back pain
I put 10 inch bagger bars on it really helped my pain.
Wide ones
Mine are the wide ones 34.3 inches wide. OEM I believe is around 30 inches. Grip angle is a little straighter also, I really like them. ;) ride safely fearless
Bullet Proof
