Kingpin motor trike not level
Aug 8, 2015
5
1
Toronto
First post, need help. The right rear side is 1.5 inch lower than the left. Looks terrible Tried washers as suggested by dealer but made no difference . Tried adjusting coil over shock but it seems not to make a difference whatsoever . All suggestions welcome ..... Thanks
How long has your trike been built? Has it always been this way?
I am looking for similar answers for my 2012 MT Pheonix IRS conversion. R/H side about 1" lower than left. Checked with the installer (a knowledgeable and respected guy) and so far, no answers. Post if you get a clue and I'll do the same. I'm compensating a little by adding a couple lbs extra air in right rear tire... :Shrug: So far, it doesn't seem to be "hurting" anything, just annoying knowing it's that way... :(
since i got it 5 months!!!
Will do.. you do the same...thanks
Funny i HAD the same problem out the door with my 11T/G.. My dealer removed the body realigned the mounting bolts/holes while i waited.. About an hour.
i have removed the body once but can't see and easy adjustments except maybe problem with the shocks....my trike is a Victory Kingpin 2012 on a MT kit...
Does anyone know what replacement coil over shocks and air shocks i could use for this trike.. Motor Trike Victory Kingpin..I want to replace them all ....Thanks
Jurgen0419
