Kingpin motor trike not level
First post, need help. The right rear side is 1.5 inch lower than the left. Looks terrible Tried washers as suggested by dealer but made no difference . Tried adjusting coil over shock but it seems not to make a difference whatsoever . All suggestions welcome ..... Thanks
How long has your trike been built? Has it always been this way?
I am looking for similar answers for my 2012 MT Pheonix IRS conversion. R/H side about 1" lower than left. Checked with the installer (a knowledgeable and respected guy) and so far, no answers. Post if you get a clue and I'll do the same. I'm compensating a little by adding a couple lbs extra air in right rear tire... :Shrug: So far, it doesn't seem to be "hurting" anything, just annoying knowing it's that way... :(
since i got it 5 months!!!
Will do.. you do the same...thanks
Funny i HAD the same problem out the door with my 11T/G.. My dealer removed the body realigned the mounting bolts/holes while i waited.. About an hour.
i have removed the body once but can't see and easy adjustments except maybe problem with the shocks....my trike is a Victory Kingpin 2012 on a MT kit...
Does anyone know what replacement coil over shocks and air shocks i could use for this trike.. Motor Trike Victory Kingpin..I want to replace them all ....Thanks
