Wind Deflectors
Is it possible to post a photo with them close to being in place showing where the turn is in the way.
One of the problems is the Roadking uses a different face plate as I call it. That is where the 2 holes are, it is tapered downward.
I have spent hours looking at photos on the standard Roadking to see what the difference is.
The easiest solution I see, going by photos and research, is to widen the mounting plate. You know cut off the mounting point at some level to get it more rearward to clear the signals. I thought of adding the Roadking running lights with signals and then they would work.
The running light/turn will not fit the free because of the face plate. Once you remove the 2 bolts it is lose and very well come off with the signals in place.
This is just a thought at this point. I will get to it later on, got too many fires started at this time to do anything.
About hour and half one way. Problem is we never go that direction. I got to pick up a fromt motor mount for my Dyna so ill pick one up then. Just dont know when that will be. Lol
I got a teen ager and a wife that has to go, go, go.
wzejda
