Changing Oil 2013 Triglide:
Sep 28, 2013
31
Humble,TX
Dale
Anyone out there have any success changing the engine and transmission oil without jacking up the trike? Having trouble locating the drain plugs with the bike sitting on the garage floor. Don't laugh, never had any issues changing the oil on our 2 wheel Goldwing's but this Harley is a little different.
I never jack mine up to change the engine ,trans or primary oils. There is a plug beside the engine oil drain plug that drains the crank case so don't loosen it. Get a service manual. I am not sure if the owners manual shows it. It is very easy to do. The oil filter will make a big mess so be prepared for that. There are ways to minimize the mess but I found it's just easier to clean up the mess it makes. Most important is to get a service manual and the TG supplement.
No troubles at all changing any of the oils. I have an old turkey pan to catch the oil - it fits perfectly under the engine. I loosen the drain bolt, slide the pan under, squeeze my hand in to unscrew the bolt the last few threads and let the bolt fall into the oil. Then use an extending magnet to retrieve it later. Dump the oil into a plastic gallon jug and take it to Pep Boys or any other auto parts/quick lube/gas station to dispose of it.
Back in the day I just used aluminum foil to make a deflector for the oil. Then I made a filter oil catch thing out of a liter bottle(a little better). Then after installing a new filter, I just spray the whole area with parts cleaner or an engine cleaner and hose off = clean as a whistle. ThumbUp
Changing Oil 2013 Trike:
Thanks guys for the info. Just wanted to make sure I was not missing anything. Guess I need to get off the creeper and get down on the floor so I will have more room to see what I am doing.
Once you've done it a couple times you will be able to do it by feel afterwards. I've changes fluids so many times I don't even have to look anymore, granted life is a whole lot better with a table lift these days.
Use 2x6's or 2x8's to elevate bike when you decide to park it to do the changes for oil. Gives you just a little room for the pan and your hands.
dan
Oil was so easy...pan fit under drain and filter...motor heads warm to the touch...pull drain plug and let drain till gone...then used Rivco filter wrench for the filter...let all drip in pan...clean and replace filter and oil plug...sprayed front of motor with Liquid Wrench and let drip dry...three quarts to start and then top off...No mess, No fuss...
I bought a 2010 2 years ago, have had Harley change it,but I just did it myself for the first time two weeks ago. I bought the oil from Harley Low Profile Oil Drain Pan-63795-10
Part Number 63795-10
worked fine
I use the plastic car/truck drive on ramps. You need 3. Im on the tablet at the present so i am not capable to post photos right now. It really makes it simple and easier. Find some one with
wzejda
