2015 HD freewheeler. ...Hot hot!
Jun 12, 2015
5
parker, co, usa
Just bought my most amazing freewheeler a few days ago. LOVE IT ! I'm new to riding..about 6 months, and previously rode a 2006 Honda 750 motortrike. Now, on my new beast..I'm having to learn and get settled in. I noticed after riding 39 or so miles the HEAT from the right side of the bike is really. .HOT. Almost so much so that it is uncomfortable. I ride with jeans and proper riding boots. After a relatively short ride yesterday, I took pants off (at home..lol) and noticed the inside right calf of my leg was all red and splotchy....like when you get burned. It did fade over time and today doesn't bug me at all. Went to the HD shop and told them and they ordered heat deflectors.....waiting. seems like they are going to be placed up higher than the lower leg area though. So....wondering if any other freewheeler owners have noticed this exceptional heat on the right hand side and if so...what did you do about it? Thank you, sincerely, in advance for your time and any suggestions and feedback.
Tiffany
Hi Tiffany,
Welcome to the Forum, and Congratulations on your New Trike! ThumbUp
The heat your are feeling is probably from the catalytic converter which is right below your right foot.
The most inexpensive way to get some relief from that heat is with Floorboard Extensions.
Click on this LINK to see more info on them.
They will also make your ride more comfortable, as they give you more room to move your feet around.
There are also other things you can do, highway pegs, removing the catalytic converter, and a host of other things that will reduce the felt heat and actual heat.
There are a ton of threads on the forum about how to reduce how much heat is felt, and how to reduce the actual heat the engine is producing.
I would do the Floorboard Extensions first, and ride it for awhile to see if that does the trick for you, or if you want to reduce the felt heat even more.
Have fun on your new FW! :)
Welcome to TT!ThumbUp
As Keven said, moving the floorboards outwards and highway pegs can take care of the heat you are feeling. Tank lift can help too. I have both of those items from DK Customs. Excellent product from a great company.
Welcome aboard what has already been mentioned are the first steps to relief. Elimination takes more serious steps. We all do what makes us comfortable.
So.......went riding again today ...A long steady ride..about 80 miles one way, about 70 mph was the average....The heat didn't nearly bother me today like yesterday. The difference from today and yesterday was I was on the hwy..Instead of going through town with several stop lights, etc. The consistent stop and go, at slower speeds ...With less wind, obviously is part of the heat issue. DUH....I'm learning ! I'll definitely check into the floor board extensions. MUCH APPRECIATED FOR THE ADVICE!
Tiffany,
Floor board extensions as said also don't hug the tank with your legs, very common with new riders.
I have the 1" floorboard Extensions installed on my Freewheeler also the V Twin Manufacturing 2" extended rear heal shifter arm and the 3 1/2" long LA Choppers front extended shift peg ( Ext shift peg not needed in rear, it will get in the way of setting the parking brake) All these items are a must on Trikes in my opinion. ( After all these items are installed and adjusted correctly all is great)
I have all the room in the world with my floorboards, shifting is better and the big one heat is managed much better. ThumbUp
Enjoy your new Trike....
Ride Safe, :)
Bill G
You can see the extensions in these pic's. Look between the floorboards and where they mount to the frame, there you will see a 1" extensions. The kit comes with 1" spacers and longer mounting bolts. (It takes longer to poor a glass of tea and get the tools out than it does to install them)
Ride Safe, :)
Bill G
I guess, I could get the floorboard extensions. But, I have to confess, I have never had the heat issues that other had from day one.....
Springman
I don't really have the heat issue either but after you install them you will notice a difference in the heat levels. The main reason I installed them was for more floorboard room and comfort. ThumbUp You would be surprised how much of a difference they make in the comfort department and there so reasonably priced and easy to install.
Ride Safe, :)
Bill G
Bill G.....where are the pics you attached? Still learning the ins and out around this forum. I see where it says thumbnails attached bit nothing opens there?
And for a newbie such as myself....With simple mechanical skills...would I be able to add the floorboard extenders myself...ya think???
Again....THANKS FOR THE INPUT !
You sure would be able to do the install yourself. Just a matter of removing bolt(s), take new longer bolt and spacer, and re-attach.
Welcome to the forum and congrats on your new Freewheeler. I too suggest the floorboard extensions and also the tank lift kit from DK Custom. You should be able to do both yourself. The tank lift kit will raise the gas tank up 1-1/2" to 2" which let's more air circulate around the engine making the engine run cooler and also reduces air updraft to the rider. As others have stated both kits are simple too install and only takes about 15 minutes each.
Sunman
Hopefully you will be able to see them this time. 1" Floorboard ext, the 2" V twin manufacturing ext heal shifter arm and the 3 1/2" LA Choppers front ext shift peg.
Yes, the floorboard ext are pretty easy to install.
Ride Safe, :)
Bill G
Check out the leather heat deflectors that just fits under the saddle, Ordered them off E-bay for $45.00 and free shipping. You can pay more for them if you wish?
How's Harley compare in price? Plus they look better!
Fuzzy. ...oooooie...looks sharp! Yeh..I ordered them from the HD shop...70 dollars....ugh...now I realize there are other options.....no one in my family rides, no close friends...so I'm figuring this all out on my own so far.
NOWWWWW....LET ME ASK YOU THIS PLEASE.... I WANNA ORDER A SISSY BAR AND BACK REST....The HD shop gave me their catalog and I am floored that the bar alone is 249 and then you still have to get the backrest pad mount for another 70......
Where else can I order them??....I'll check ebay, thanks for that idea.
Welcome to owning a Harley, HD stands for hundreds of dollars. Lol :gah:
With the Freewheeler for the most part your stuck with Harley parts. The backrest assembly is specific to the Freewheeler Trike. The backrest pads fit all the Harley models.
Ride Safe, :)
Bill G
Funny Bill.....made me laugh...well, that's what I am working for right now. .....Most worthy workable cause in a long time!
Riding on......to work now....woot woot
Thank You - Billy G
Billy G - I just wanted to give you a big shout out of THANKS!. I am having the same issue as Tiffany with the the heat from the Cadillac converter frying my right leg! The deflectors sit too high and are of no use for this issue. Your detailed post with accompanying pictures was extremely helpful.
When I read the other posts about floorboard extensions, I was envisioning the extension to be lengthwise, which I didn’t find to be of benefit. When I saw your post with the pictures, BAM! I finally understood and then it all made sense. And, you were even thoughtful enough also provide a link for purchase, which has the part info. I am going to give it a try . . .
YOU ROCK!:biggrin::biglol:
Ron A
