Looked at it this morning....fortunately the bolt did not break off, nor are the threads messed up. This is the first time I lost one of these. Will be replaced prior to riding it again.
Hi Kevin, I put a isolator type link that has the elastic isolation in the middle & is adjustable to find neutral mounting. I bought it from Jim Murphy at Lehman/Champion Co. It stops the pounding on the mount form being solid mounted.
I do find there is slightly more engine movement, but not a problem, & everything is staying tight.
But when I received the unit it was sold by Competition Cams. I still have the part # I think if you find a need. But the cost was less through Jim.
