Has anyone added these rings to headlight and passing lamps. I have not seen them on any bikes yet. Not sure who sells them. I remember seeing 360 degree rings in an add a while ago.
I have the Truck Lites and LED Rings, they are great with no problems. Sure light up the road and the LED rings look great too!
View attachment 24541View attachment 24542View attachment 24543
What wheels are you using on the rear of that Trike ?
Yep, here are two wheel pictures. Ol skool stuff with the ole wide whitewalls too whitewalls too!View attachment 24577View attachment 24578
Darth,
is is this a plug and play setup? Just replaces the existing bulb or do you have to run additional wiring?
Plug and play for both... the headlight is the HD Daymaker, so you just take out the old and put in the new. For the turn signal/running lights, you literally just take out the bulb and plug the LED board in.
