2014 TriGlide - Where is the Fuse Box Wire Terminals
Where is the Fuse Box- Wire Terminals
I want to wire in a set of small LED's
Fuse panel is under the left side cover. Be careful wiring direct , you have a can-bus system on there that is expensive to repair if something overloads or shorts out.
What I'm going to do for electrical hook ups ( Gerbings heated gear, LED lights, etc) is buy a separate fuse panel with a relay built in, wire it directly to the battery posts ( always hot) and then wire my accessories into this fuse panel, this will insulate the bikes electrical system...
just FYI
just FYI
That's what I did on my Goldwing. But what is the relay for?
Has anyone found a really good fuse panel? I tried Lewis at Electrical Conn. And that was his only product I didn't like. Found it had poor quality.
BertieEly
