Stallion tracking issue
Nov 2, 2013
19
1
Queensbury
Larry
Hi fellow Stallion owners- Just curious: The Stallion, (thanks to ALL your suggestions), is
better than ever and indeed, riding it more than the 2-wheeled bikes of yesteryear.
Not a big issue, but at highway speeds, (level & straight), if I momentarily take my hands
off the wheel to see how it tracks, it pulls gently to the left. Anyone have a comment/suggestion
here? Obviously, unlike an alignment on an auto for such an issue, there's no such thing, (remedy?) here.
Thanks for any response... Lar waiview178@gmail.com if you care to write me directly...
I noticed your down south. Is the road tapered down to the left? Is there a breeze coming from the right? Just a thought.
Road Crown is my first feeling about what you are experiencing.
The only mechanical issue MIGHT be loss front axle bearings. Not very likely because the axle is pinned. There might be enough wear in there to cause it to be a little loose. Lift the front tire up and see if there is any side to side movement.
Otherwise it might be something that you live with because it is so slight.
Actually I live in Queensbury, right next to Lake George and AMERICADE. Thanks again for the response. With only 12,000 miles, I hope it's not the bearing but will certainly check on your notions.. Lar
Thanks for such a quick reply. The road "appears" flat/level and it doesn't happen with my car. Doesn'tsound likea safety issue and I don't feel like I'm fighting with the wheel. Lar
Trike#1
