New Version SE Compensator Installed
Sep 16, 2009
805
71
Myrtle Beach, SC
Tom
I got my 3rd and the newest SE Comp installed. I added the GMR Compusaver oiling tray and Steve @ GMR gave me a PEEK washer to test long term on my trike to replace the bearing washer that comes in the lastest SE Compensator kit. The instruction are not much different from the 1st version SE Comp. You will need a 3/4" torque wrench and a 1 3/4" wrench or a locking wedge bar.
Its been reported that Harley doesnt want the dealers selling the adhesive for the "scoop" that needs to be installed in 2013 and older Big Twin models. HD want the customer to come to the service dept at your local dealer and pay them to install it. Well Im not made of money and most others are not as well. Plus I want to do my own work as much as I can and if you can by the adhesive its $50 from HD.
I got info from another forum that the supplier of the adhesive is Lord and the adhesive is Maxlok MX/T6. You can by the 50ml for $31 which includes shipping and a plastic adapter to use in your caulking gun >> http://www.chembar.com/adhesives/lord-maxlok-mx-t6/
I drilled a few holes in the "scoop to let the adhesive push out and make a better bond with the inside face of the outer primary
The GMR Compusaver oil tray does require that the ribbing be ground out to fit the primary cover over it. The Compusaver tray is a great design to funnel oil into the bore of the SE Comp to keep it well lubricated.
The GMR PEEK washer replaces the stock bearing washer to eliminate any possible bearing failure due to the primary oil has not filtering and will become contaminated with debris and ruin the bearing at some point. I will be checking the washer periodically to see how its wearing for a long term report.
I was able to get in a 120 mile ride today before the thunderstorm and can report a significant reduction in the chattering noise associated with the previous SE Comp. Especially at idle and under load.
View attachment 21163View attachment 21166
View attachment 21164View attachment 21165
Spoke to Steve a few weeks back and was going to send a test washer, but have not seen it yet? maybe the mule died??
Like to hear more on your findings on this product.
You have any better pics of the tray?
Newer design seemed like a good idea. Was put in a while ago for me. Thought oil slinger would make a difference. I usually get 25k out of my Comps. Only got 20k this time. Replaced for 3rd time at 70k service last month on my '10 TG.
Here is another view
Thanks!! That channel or mount is that part of the oil flow to the compensator
Yes. It has round openings to flood the comp with oil.
You need to get the adhesive which the dealers are not selling to the public..
http://www.harley-davidson.com/store/big-twin-compensator
See my first post. The adhesive can be purchased from the vendor I linked
Does anyone have the part number for the newest (3rd generation) SE Compensator?
42200064A
I just opened up my primary with the new designed compensator. Not happy..Metal fretting and lack of oil in key areas.And making noise since day one.
Will be testing GMR washer.
If your metal amount on the drain plug magnet is excessive you may want to get a new Inner Primary Bearing and possibly replace the clutch hub bearing
Drain plug is not bad ..it is all at the compensator real fine metal flake on the components building up..
Primary bearing was replaced last winter..clutch bearing was still good..
