Heel Toe shifter Not for Me!!
I've been using heel toe shifters on Harley's for years so it was natural for me to have one on my Wing. I used the factory pegs and toe shift for several months, just wanted foot boards and heel toe shifter since that what I've been used to using.
I had a heal-toe shifter on a 1200 and a 1500. I like them, the trike I'm having built will have one on it. My bride has a Yamaha V-Star 1100. It came with the heal-toe shifter. She's not confident in it yet. She still uses the toe to do both up and down shifting. To each his own!
I guess it might depend on what you're used to. I learned to ride with a trike (Suzuki C-50) that had a heel-toe shifter. I wouldn't want to go without. But whatever works for you! Enjoy riding!
MarciaG :)
The heel shifter is one of the first I pull off. I feel it restricts my movement. I install a Harley spacer to keep it looking clean. Take the removed shifter and put in my tour-pac. Can't tell you the number of times I've lost a shifter or a friend has.
o~\o
I too am having difficulty getting used to the heel-toe shifter. I'm going to master it one way or another. I do like the floorboards.
It saves your boot tips . I had it on my 80 Wing. I sort of like it. Works best with small shoe size mine is an 8 1/2
I recently installed the Kury heel toe shifter on my 2012 Wing. The Wing has a CSC Viper Kit on it with Aquashields.
The shifter went on pretty easy. I didn't have to remove anything and there were several inches of clearance above the Aquashields to the floorboards.
I've had heel toe shifters on a couple of other Wings and I always liked them. Especially the floorboards.
Which trike kit do you have?
When I got my 2005 Champion, it had heel toe and Kury floorboards. I liked the look so gave it a try for a couple weeks and couldn't get used to it. Missed shifts and always looking down to find my feet and the shifter. Took shifter and floorboards off and used the stock shifter and a Showchrome peg extension that lowered the foot pegs and extended them forward for a more cruiser-like stance. I like this set-up a lot.
I also have a 2005 champion Kit on a 1800 Goldwing frame love the trike but that darn heel toe shifter bugs me,I wont to keep the floorboards on if all possible.
It's been a few months since I ditched my setup. There may be a problem with getting your toe under the shifter with the floorboard, if I remember correctly. The shifter is not adjustable, although these guys make a gizmo that allows you to adjust the shifter..if you really want to keep the boards, then maybe this might help: http://www.dhsracing.com/GL-1800.htm
I clicked on your link but get a message; "Web page in not available".
I'd be interested to see what they have.
Hmmm.. I clicked on the link I posted and it came up. Maybe Google DHS racing and see if that gets you there--They have a few products and the shift linkage is down the page a bit.
I'd never used an H/T shifter until I got my trike four months ago. It took a little getting used to and I did add the extension to gain a little more room for my size 12's. 11,000 miles later, I'm pretty much a fan!<img src="images/smilies/smiley-score010.gif" border="0" alt="" title="10" class="inlineimg" />
I'd never used an H/T shifter until I got my trike four months ago. It took a little getting used to and I did add the extension to gain a little more room for my size 12's. 11,000 miles later, I'm pretty much a fan!:10:
Talk to me about the extension as I also wear a size 12. Always interested in something to make life easier. Thanks.
I'm not all that sold on a heel shifter so I only use the toe. I have Kury floorboards with heel toe shifter. I raised the toe portion up an inch and out an inch so now I can get my boot under the toe shifter and gives me more forward room on the floor board. The heel shifter is still there but I don't use it. Cost about $5.00.
I also love the Heel/Toe set-up on my VTX 1800, have stock shifter on my GW Trike, was planning to install H/T but have read it can cause transmission issues on the GW so have stayed away from switching over. Have a Champion Trike kit with rain guards, think either shifter would fit on it.
Stu Oatman, tech advisor for Wing World mag has recommend you don't use a heal/toe shifter due to evidence he has seen to damage to shifter forks because of too much heal pressure.
Makes sense to me. I think some may be inclined to stomp down with a heel. With the toe, it's a more light touch going both ways. I know when I had my heel/toe shifter, I thought I was going too hard in trying to find the heel shift.
I had the Kuryakyn one on my trike when i purchased it. Tried it for a while and noticed a couple of things. First off I would miss shift ups especially from 1st to 2nd, would end up in neutral. The other thing i noticed is that the heel part was to low for my pegs ( Mine was the add on without the floor boards). So I would have to awkwardly move my heel downward to shift. I have just removed it and restored it to its original setup. I have no more trouble with shifts, it feels a lot more natural to me, and no more shifting to neutral. I doubt I will return the heel toe shifter to my ride.
Steve
Kickstand_Korner
