Repair of your Stallion....
Jan 11, 2011
45
14
Conway, AR
Just wanted to remind any Stallion owners out there if you are having a hard time finding someone to work on your Stallion, I was the Lead Technician for the Stallion at TBMS for 3 years. I moved to Arkansas to be closer to my children. I know the Stallion from front to back, and top to bottom. I have all tools necessary to repair any problem with your bike. If you are in the area, or not, give me a call and we can get your bike fixed.
I am an authorized repair shop also. I work out of a shop, not my house, and can accomodate any repair necessary. Dont trust your bike to just anybody, give me a call and lets get you back on the road! You can even ask Stallion owners on this forum as well, I know what I am doing. Feel free to message me anytime. Thanks again....Kevin Perkins
Kevin, I am a stallion owner, 2009 with a burned out fog light. I have taken the light out and noticed that it looks like you have to replace the whole harness on the system. If this is the case, do I have to order the whole harness system from Stallion? slooldt@hotmail.com
Hi Kevin,
My bro-in-law has a 2008 Stallion that he said the overdrive quit working when he presses the button. He checked the fuses and they appear to be fine. What do you think the problem would be? Thanks
Dean
Have him check the OD button they will go bad. Check and see if it has power to the button or not. If he is like me I use that button to cancel overdrive all the time on the hills so it wont shift back and forth then the only thing I have to worry about is in and out of lock up convertor.
Darrell
The bulb itself can be changed out with a little work. You can get a replacement bulb from an auto parts store, but you will need to do some splicing of the harness. Or, you can contact TBMS and see if they will offer you a replacement light that will come ready to install. If you have a reputable shop or mechanic that you trust, splicing in a new bulb shouldnt be any problem for them to swap it out.
Dean, when the button is pressed, does the O/D light come on in the Instrument Panel? If so, the button is working properly, and I would suspect either wiring, PCM, or Transmission problem. Start with the easy stuff first....
its on the shift lever left side just below the curve of the top of the handle. if the od is off a message light lower left side of message area would be on.
Hi ,
Ok I found the button. Sometimes I wonder about myself. Anyway thanks for the info will go out when it stops raining and try it out. Thanks again to all on the Forum, It is GREAT.
Terry. #696
Kevin,
I love my Stallion, but it has been a royal pain for me with break downs etc. I was going to Mo and came through Ar. the other day and my heater went out for the second time and a bolt came out of my rt rear brake causing my brakes to lock up. This happened on a Sunday with no mechanics around in a small town. As it turned out the heater relay switch was lose on the heater that is located under the hood. I put a bolth in the brake as a temporary measure. When the caliper came lose it has scarred the inner side of the rim.
I have had several issues with my 2010 stallion and not impressed with the workmanship on it when it was built. It is an awarding winning trike with the murals etc, but is it worth almost losing a life due to brakes and lost of steering and front end issues. Like I said, I love the Stallion, but not sure about the quality at times. Just saying. Kevin could you send me your phone number in a private message and I will see about coming to your shop for repairs/warranty work. It took my Ford dealership 5 weeks to repair/replace the front end.
Dean
Hello KEVIN, when you need help KEVIN is great.. when in texas go directly to TBMS ask for Jeff or Jr. call ahead and make an appt. they are good about taking care of problems and updating your trike.. If you are in the Chicagoland area please contact GOLF MILL FORD 847-470-9800 the service dept.is great Contact Cris Fanella service mgr. or Mr. Bill Giers Serv. Director. # 1 rated service dept. in Ill. :10: they are located in Niles Ill, northern suburb of Chicago.
Kevin, I have a 2009 and I have had several issues. I love the bike but there are some quality issues. Right now I am dealing with a front wheel that tilts to the left. I have had it straight and then when I drive it goes back to being tilted to the left. I measure the from the ground to the axel and the right and left side are different. It seems that the right and left side work independently and I can't believe this should be. HELP
Kevin I need help. I have a front wheel that runs tilted to the right. The distance from the ground to the axel are different from right to left. I didn't think that they should be independent. What could be the problem. The distance to the back of the arm is the same.
I have a 2010 Stallion and have had minor things untill now. We were coming back from Jackson Ms and the Stallion down shifted into a lower gear at 60 mph at 4000 rpm. Pulled off and the check engine light also came on and the OD light started to flashing. Had it checked at Auto Zone and said a shift senser (Po715) is bad. My transmission fluid is also dark. My warrenty ran out back in June of this year. They think it is internal. Going to carry it to a ford dealer in Milan Tn. this Tuesday. Hope that it is not inside the transmission for it will be costly.
Kevin, have you heard of anyone else having problems with their A/C do to the a/c line rubbing at the top bend rubbing together the radiator and the condenser line on the right side where the right tank folded and is seamed I have a bad leak , I was told that it could be a fitting but after removing the right rear tire and recharging the system I could see and hear the Freon leaking out.. the trike only has 7000 miles on it
Sorry for the late responses guys, I was locked out of my email address for months, and finally got it back. Yes, I have had experience with the lines rubbing each other and causing a hole causing all refrigerant to be lost. The line has to be replaced, and then "tweaked" to prevent them from rubbing again. Not a common problem, but I have dealt with it before. Hope this helps
2009 Stallion
Hi Kevin,
I don't know if your online or any other stallion repair techs are. I'm looking to take my 2009 to a stallion repair shop. Need 50k mile service. Replace plugs, I want to replace all 3 tires, replace fuel filter in addition to all the 50k mile service maintenance stuff. oil/filter change etc. Inspect for any other services needs like breaks/ shocks etc. I can bring it to your shop if shop still open for repairs. Any other techs if you have service recommendations where to get stallion service I'd appreciate pointing me in the right direction to find service.
Hi Kevin,
Welcome Mike. Why don't you contact MotorTrike in Troope Tx (just down the road) and see if they will work on it. After all they built it.
MelT
