Which Reverse?
Strohkr
100+ Posts
Sep 16, 2010
114
40
NORTH DAKOTA
I'm in the process of triking my 2007 HD Road King and have the option of a mechancial or electric reverse. I have absolutely no clue which one would is better or would work better and the info from the dealer and factory isn't helping much either.
Any of you have any clue whatsoever which way to go and why? I'd sure appreciate some input as I don't want to do the wrong one!
Thanks much!!
Greg
The electrical reverse came standard on my TG but if it was up to me I'd use a mechanical unit. I've had several instances of tripping the breaker trying to back up a grade. It's a pain in the (deleted) taking the seat off to reset it. - Russ
Mechanical, Hands down!
I have a 11 T/G With the standard electric reverse, And believe me it's one PITA.
I suggest Champion reverse (mechanical) I have the AIM reverse which is very similar. The Champion is just a little better in my opinion though.
I have the Baker Drivetrain reverse installed in my tranny. Pricey even by HD standards (nearly $4k for the reverse installed with new belt/30 tooth drive pulley), but everything works perfectly as advertised. And best of all, it works as if was a factory design (shifts with the foot shifter just as with other gears). Put tranny in first gear, touch a relay button on the handlebar, and mash down again with your toe - that's reverse! Pull up with your toe (no relay needed) and you're back in first gear.
I have champion reverse in two of my bikes, one is also a '07 RoadKing, never had a problem with either. Easy to install and use.
Wife had the electric reverse fall apart on her TriGlide a few months or more after it was out of warrenty. HD sent me a new one free of charge otherwise it also would have a champion reverse.
with the new triglides electric reverse it puts so much strain on the electrical system I would go back to a mechanical anyday..I am surprised more people dont have more issues with the eletrical systems on the triglides..
thats right the first year they put them under the seat..now they are on the right side under the sidecover..
I'm doing the Motor Trike Gladiator kit and I have the option of either electric or mechancial reverse. The dealer has been pushing the electric option but I think that because he said it's easier to install.
I did talk to a Motor Trike factory tech rep and he said you can control the mechanical reverse better because you use both throttle and clutch to operate it whereas the electric has one speed only. I need to back out of a tight garage space so I think I'm going to go with the mechancial instead.
Thanks for all the replies - it helps a lot to get your opinions.
Greg
Eddie 1
