rear brakes pulling to side
My rear (disc) brakes are pulling to the left, what would cause this?
Sounds like what happened to me when I forgot to release the parking brake and drove it 2 miles at 35 mph. Luckily the parking brake was nearly ineffective by then anyway.
Maybe right side is completely wore out and the left still has some meat on the pads?
Let us know what you find out.
I have seen caliper slides freeze up so on one side you have half the braking effect due to only the piston side of the pad pressing against the rotor,can be repaired by removing the caliper and sanding the slides,as long as the pads are not too worn.
Ron A
