Wiring Diagram
Sep 23, 2013
171
10
Pensacola FL
Bobby
I have a wiring diagram manual from Ford and I will be glad to help anyone that needs help.
Just ask and please try to be specific.
abs lite & brake lite stay on, checked brake fluid, reservoir is half full, is it a sensor or what? thanks in advance Larry from il.
If the reservoir is half full look and make sure that both the front and rear brakes are working. Depending on the reservoir one or the other might be out of fluid. That would move the little piston in the equilizer/proportion valve to one side and turn the light on.
Also with 1/2 fluid down you might be only stopping on either the front or rear brakes. It also could be caused by either the front or the rear being worn out causing the fluid to move the little valve also setting off the light. If you have around 25k or more on the trike check the rears first for wear. I'm betting on the rears being worn. Keep us posted.
Roger71!!
