Is the 7 hole windshield standard to fit all models. I was wondering if a Clearview windshield for Heritage/Fat Boy would work to replace the FLRT windshield. The recurve and vent sound promising to reduce buffeting.
Damn, when I saw that picture I thought it looked familiar! That windshield is from my wife's old '08 Deluxe. She didn't like windshields, so it hung from the rafters of the garage for 7 years. The stock brackets were far enough apart, BUT the grooves weren't . Since I have more time on my hands than I have brains, I drilled and machined the grooves / slots to match the brackets on a Road King windshield bracket. Fit just fine.... but the windshield was way too tall.
Used a carpenters level to measure from the bridge of my nose to mark the top of windshield. Covered the whole top 1/2 of the plastic with masking tape then used an old 8" windshield I had on my Ultra to make a nice curve where I was going to cut. Saber saw with a fine blade, and 5 sandings with progressively finer paper and TA-DAAAA a cheapo windshield that works great.
Oh, I took the old windshield bag from my Ultra, punched some new holes and trimmed the attachment piece and I have a freebie windshield bag. I also have a 5volt, 4 port USB splitter under the seat. I ran a cord into the bag so I can charge my MP3 player, or Bluetooth headset if necessary.
While I'm bragging, also made a bracket that is glued (double sided outdoor rubber tape) (the kind that hold car badges on) and covered in Velcro. I can attach my iPod and GPS to it. There is a power cord for both tucked inside the bracket.
The things an old retired Engineer does with his spare time.... a lot of spare time!
The CVO Road King windshield is a direct bolt-on,Jerry.
Thank you Dirtdobber! I ordered the lrs 20 inch and also a windshield bag (needed one anyways) I will keep ypu posted on how it goes. I use to ride a Road King with a 20 inch stock windshield and never had a problem with wind. I know the frames are similar just don't understand why the difference with wind and noise. So bad on freewheeler my glasses kept coming off!
.............................. I do get a lot of up draft... /QUOTE]
Tank lift reduced the up draft allot for me. Still get some, but nowhere near as much as before the lift.
Ok. I asked on another site and was told that HD said these will work...Called down to the Harley dealer we bought our FreeWheeler from and asked them about this:
http://www.harley-davidson.com/stor...--1?cm_sp=Monetate-_-Endcaps-_-PAC+PDP+Bottom
They say this will bolt up and work...*
Before I get all excited about it... I wanted to check with you all*
If using a running light bar with turn singals incorparted with them then they will work. I spent several weeks to check to see what will work. If you drop by a hd shop look at the 2015 roadking then you can see what needs to be done.
Will it work, yes. Just got to move the turn singals.
still get a lot of updraft from beside the tank just in front of my knees.
Hey Red59! I got my 20 inch LRS and went for a long ride yesterday. It has helped a ton with the head bob for sure and has reduced the updraft some but not all but definitely a more enjoyable rideepper:
I went to Sturgis this year. Memphis shades put a road king removable fairing on my freewheeler, fit perfect no more buffeting no more updraft. even the stock fittings on the freewheeler fit
