which led white bulbs
fastfreddy2015
90+ Posts
Nov 22, 2015
98
32
I live in Pasadena, TX
Thinking of changing out my OEM low beam bulbs and replacing them with a brighter/whiter LED bulbs. Read about the silver ultra and the PIAA extreme white 55/w bulbs, both sound like what I'm looking for. Don't do much night riding want mostly for visability purposes. Would love some input /ideas on what some of you are using. My main question is can I change out only the low beam bulbs and leave the high oem bulbs in place or do I have to change them all out at the same time ?
I don't know a thing about those LED bulbs Fred but if they operate on 12 volts and fit in the OEM housing then there is no reason I can think of that would prevent them from working. I'm sure there is either an internal or external voltage compensation circuit because LEDs so not operate directly on 12 volts but that's another topic completely.
It's not like the directional signal lamps. The high and low beams are either switched on or off... :xszpv: :xszpv:
shawn.s.prescher
