Which conversion to get? Avoid?
Considering a GW trike. Reading these informative pages, I've learned of drive shaft problems and others. So simple question:
What year GW should I trike? Which should I avoid?
Which kit to use? Which kit(s) to avoid?
We'll be riding 2 Up and traveling.
Thanks so much
2006 & up
I tested and studied all the major brands. My and my wife's choice was the Hannigan. IRS, extended wheel base, wider stance, smoothest, least maintenance, rear end off set to align w/the Wing drive shaft output(no extreme angle for the shaft to run in)
Your wife will thank you for the longer wheel base of a Hanningan. Much smoother ride for her!!!!
Thanks so much
These are opinions based on nearly 4 yrs of tested and studying prior to picking the conversion we wanted.
I have this one for sale..if you maybe interested
http://www.triketalk.com/forum/threads/32520-2008-Level3-with-2015-HTS-RoadSmith-Trike-Kit
[FONT=Liberation Serif, serif]Extra's include..[/FONT]
[FONT=Liberation Serif, serif]Custom Marbling Paint[/FONT]
[FONT=Liberation Serif, serif]Custom Color Matching Timing Cover[/FONT]
[FONT=Liberation Serif, serif]Custom Painted Matching Battery Side Covers[/FONT]
[FONT=Liberation Serif, serif]Custom Painted Matching Dash[/FONT]
[FONT=Liberation Serif, serif]Custom Painted Matching Fairing Side Pockets[/FONT]
[FONT=Liberation Serif, serif]Custom Painted Matching Valve Covers[/FONT]
[FONT=Liberation Serif, serif]Louvered Chrome Transmission Cover With Custom Matching Paint[/FONT]
[FONT=Liberation Serif, serif]Factory Honda CB Antenna for GL1800[/FONT]
[FONT=Liberation Serif, serif]40 Channel Factory Honda GL1800 CB Radio Kit[/FONT]
[FONT=Liberation Serif, serif]Centramatic Front Wheel Balancers[/FONT]
[FONT=Liberation Serif, serif]Chrome Front Rim[/FONT]
[FONT=Liberation Serif, serif]Brake & Clutch Speed Bleeders[/FONT]
[FONT=Liberation Serif, serif]Adjustable Handlebar Riser[/FONT]
[FONT=Liberation Serif, serif]Convex Mirrors With Turn Signal[/FONT]
[FONT=Liberation Serif, serif]Progressive Heavy Duty Fork Springs[/FONT]
[FONT=Liberation Serif, serif]Superbrace Chrome Fork Brace w/Fork Protectors[/FONT]
[FONT=Liberation Serif, serif]Wing Soft Heated Seat [/FONT]
[FONT=Liberation Serif, serif]Utopia Driver Backrest [/FONT]
[FONT=Liberation Serif, serif]F4 Scratch Resistant Clear Windshield With Vent[/FONT]
[FONT=Liberation Serif, serif]Rivco Driver Floorboard w/Heel Toe Shifter[/FONT]
[FONT=Liberation Serif, serif]Jon's GPS Mount[/FONT]
[FONT=Liberation Serif, serif]Wired For GPS Into Intercom[/FONT]
[FONT=Liberation Serif, serif]Mic Mute Intercom Noise Eliminator Kit[/FONT]
[FONT=Liberation Serif, serif]Doran Trike Air Pressure Tire Monitor System[/FONT]
[FONT=Liberation Serif, serif]Front Butler Cup 20oz[/FONT]
[FONT=Liberation Serif, serif]Rear Butler Cup 34oz[/FONT]
[FONT=Liberation Serif, serif]Dual Adjustable Baker Air Wings[/FONT]
[FONT=Liberation Serif, serif]Baker Adjustable Hand Wings[/FONT]
[FONT=Liberation Serif, serif]V3 Digital Music Player[/FONT]
[FONT=Liberation Serif, serif]Kuryakyn Passenger Transformer Floorboards[/FONT]
[FONT=Liberation Serif, serif]Rivco Triple Chrome Plated Adjustable Flip Up Armrests[/FONT]
[FONT=Liberation Serif, serif]Hyper Lite 3 Way GL1800 Brake/Running/Turn Signal LED's[/FONT]
[FONT=Liberation Serif, serif]Roadsmith Chrome Nerf Bumper[/FONT]
[FONT=Liberation Serif, serif]Electrical Connection Power Plate Fuse Block [/FONT]
[FONT=Liberation Serif, serif]Argus Battery Bug[/FONT]
[FONT=Liberation Serif, serif]Gerbrings 12 Volt Battery Cable[/FONT]
[FONT=Liberation Serif, serif]Trunk 12 Volt Socket[/FONT]
[FONT=Liberation Serif, serif]Kuryakyn Trunk Organizer w/Mirror[/FONT]
[FONT=Liberation Serif, serif]Trunk Carpet[/FONT]
[FONT=Liberation Serif, serif]Trunk Rack[/FONT]
[FONT=Liberation Serif, serif]Back Off XP Rear Brake Modulator[/FONT]
[FONT=Liberation Serif, serif]Performance Stainless Belly Pan[/FONT]
[FONT=Liberation Serif, serif]Fork Tube Tunnel Filler [/FONT]
[FONT=Liberation Serif, serif]LED Fog Lights[/FONT]
[FONT=Liberation Serif, serif]Plastic LampGuard Headlight Protectors[/FONT]
[FONT=Liberation Serif, serif]Ergo II Highway Pegs [/FONT]
[FONT=Liberation Serif, serif]Iso-Grip Set w/Chrome Accent Ring[/FONT]
[FONT=Liberation Serif, serif]Rust Free Easy Mount Seat Bolt Set[/FONT]
[FONT=Liberation Serif, serif]Wide Chrome Brake & Clutch Levers[/FONT]
[FONT=Liberation Serif, serif]Handlebar Helmet Holders[/FONT]
[FONT=Liberation Serif, serif]Trunk Side Storage Panels[/FONT]
[FONT=Liberation Serif, serif]Chrome Euro Saddlebag Light Grills [/FONT]
[FONT=Liberation Serif, serif]Chrome Metal Lower Steel Cowl[/FONT]
[FONT=Liberation Serif, serif]Chrome Passenger Floorboard Side Covers[/FONT]
[FONT=Liberation Serif, serif]Chrome Side Fairing Accents[/FONT]
[FONT=Liberation Serif, serif]Chrome Luggage Rack [/FONT]
[FONT=Liberation Serif, serif]Chrome Trunk Brake Light Grills[/FONT]
[FONT=Liberation Serif, serif]Chrome Saddlebag Light Grills[/FONT]
[FONT=Liberation Serif, serif]Chrome Rear Door Pouch Accents[/FONT]
[FONT=Liberation Serif, serif]Chrome Trunk Moldings[/FONT]
[FONT=Liberation Serif, serif]Chrome Battery Side Cover Accents[/FONT]
[FONT=Liberation Serif, serif]Chrome Radio Knobs [/FONT]
[FONT=Liberation Serif, serif]Chrome Gas Tank & Side Pocket Lock Key Covers / With Extra Key Made Into The Cover[/FONT]
[FONT=Liberation Serif, serif]Chrome LED Fairing Air Intake Grilles[/FONT]
[FONT=Liberation Serif, serif]Chrome Exhaust Turndown Tips[/FONT]
[FONT=Liberation Serif, serif]Chrome Reflector Grills[/FONT]
[FONT=Liberation Serif, serif]Chrome Front Fender Tip[/FONT]
[FONT=Liberation Serif, serif]Chrome Front Fender Filler Accent[/FONT]
[FONT=Liberation Serif, serif]Chrome Lower Front Cowl[/FONT]
[FONT=Liberation Serif, serif]Chrome Front Fairing Trim[/FONT]
[FONT=Liberation Serif, serif]Chrome Mirror Accents[/FONT]
[FONT=Liberation Serif, serif]Chrome Frame Covers w/Rubber Inserts [/FONT]
Please clarify your thoughts again with regard to the thread statement:
"What year GW should I trike? Which should I avoid? "
Your reply indicated "2006 and up".
Which question does this answer apply to?
I think he was suggesting that a 2006 and up Goldwing should be the choice to convert.
Extra's include..
Chrome Front Rim
Jon's GPS Mount
Argus Battery Bug
Trunk Carpet
Trunk Rack
LED Fog Lights
Chrome Luggage Rack
Chrome Radio Knobs
Nice. I PM'd you for more photos.
I wonder what he has against 2005 and below
Honda made a few changes between 05 & 06. The added premium audio with an amplifier (the most noticeable change). They also reinforced the weaker points on the motorcycle frames where they had seen cracking and changed the length of the output coming out of the back of the engine where the driveshaft fits.
I believe 'o6 was also the year the radiators were enlarged; better cooling.
As far as what conversion you will be getting alot of different opinions. But one of the most important is who you select as the person/company to do the conversion. A good installer makes the conversion work nice no matter which of the major brands. A bad installer will make the very very best conversion be a real hassle to deal with. That good installer will help you in making the right decision for what you need and are looking for. You are not that far from Houston Tx area where the owner of this site has a conversion business and handles several of the name brands. Suggest: you shoot Bazooka a PM and get some advise and maybe a conversion.
Absolutely correct. The installer is the key
Yes i remember all of that, except i think the 05's got the frame reinforcements
Roger71!!
