Where's The CAT
Mar 18, 2011
136
15
chicago,illinois
I just took possession of a '19 FW and have been asking the folks in the service department lots of questions about Engine, transmission etc. I'm surprised at the uninformed answers I've received.
So if you willing to indulge me I'll ask 2 questions:
Where is the CAT located in the exhaust system?
What is the proper procedure to adjust the rear suspension?
I'm headed out in the morning to the Cajun Country HOG rally and want to be able
to have the most comfortable ride I can!!
Thanks for reading my post - Prompt responses will be appreciated.
Russ
Congratulations on your 2019.:Dorag: You got the fastest color. We will need pictures.
They did away with the rear air shocks, and the adjustment for the new shocks is under the seat.
Depending on the load, I would use your owners manual as a reference, but you could start in the middle & make adjustments up/down if too stiff or your bottoming out. Setting your rear tires to 22psi cold will help the ride. Many members here have been using that setting for years on FW & TG.
Your CAT is in the exhaust kinda below the oil dipstick cap.
Congratulations hdruss. We need some pictures of that beauty. My advice replace those stock shocks. As soon I got my tri glide I added a lift and 13 next gen shocks from DK custom. I'm happy with that set up. But there are many good brands of shocks out there. Just do your research.
dyno56ca
