Don't want to guess. Look under the rear of the trike and see if there is a sticker with the mfg. info on it. Usually, they have some identifying info on them somewhere.
Thank y'all for your help. I have an issue with the rear end. I just got of a 600 mile round trip this past weekend and when I went to leave work Tuesday something popped and then the wheels quit pulling. The drive shaft will move in neutral and not when in gear so I know its in the rearend. Have you ever had this problem come up and if you have what do I need to be checking out first?
thanks,
Chuck
Ok....found out it was the Brake Drum. I think ever who put brake shoes on before I got it didn't torque the axle nut down to 217 ft pounds. Does anyone know what vehicle the wheel on this kit will fit?
