Trike kit MFG. number
Vulcanscott
30+ Posts
Feb 10, 2023
32
26
chandler
?s I have 2008 Motor Trike 1800 GW . IRS where do I locate kit serial number and year model was told 2012. also was there a registeration for the kit showing miles at install? Thank You in Advance
On solid axle shaft driven bikes, the rear end number is stamped into the TOP side of the pinion snout (above the driveshaft attachment point). On solid axle belt drive bikes, it is on the back side of the main carrier housing. Honda IRS the number is stamped into the differential support just below the rear cover. Belt driven IRS kits, the number is stamped into a plate that is attached to the center of the aluminum carrier.
Eddienorman
