What is the proper low beam bulb for a 2008 Stallion?
Sep 19, 2017
133
17
Clinton Township, MI
Greg
Hi,
I'm not sure I have the correct low beam bulb in my 2008 stallion. I have an H9 but I don't believe that is what should be in there. I'm also looking for a brighter bulb to use and or switching to an LED. Any suggestions for me?
Hi,
Actually both high and low bulbs are the same number!
when I changed mine, I just found the brightest H9 at the auto parts store. Now Ted ordered PIAA bulbs which are good and bright but not cheap. Also adjusting them helps a lot. I have adjusted a few for people around here as they seem to be adjusted too low from the factory. 4mm bit to adjust . Lift hood and Mark with tape on the floor the spot for both beams and raise lower or side to side as needed. Tom
dhinzman1
