haynes 57
5+ Posts
Hi from Alabama. I have a new to me 1997 gl1500 trike with 88000 miles. Tire pressures are 41 F and 22 R. The trike has a Ford rear end. It starts and runs very well. The trike was built by the first owner from a kit. The second owner cobbled many things(tire pressures, ring of fire, no brakes, plastics broken etc). My other hobby is restoring 57 chevys,so these problems did not sway me. However the trike's rear seems VERY stiff. The second owner had a friend install "new shocks" with coil springs and no air. They look awful and are very rigid. The install left no room for exhaust. This is the problem i am rambling about. It appears the trike"s lower shock mount was reversed and is pointing down. This caused the length of the shock to be 20 1/2 inches on the right and 22 on the left. I just wanted to make sure if this was ok. They do not appear to operate very well at the present. If the mount is reversed the length would be appx. 12-13 inches. If you know the length of your shocks Please reply. Yes I know different trikes have different sizes, but 20 inches seems very long. Thanks for your info. Gary - By the way this is a SA.
